oil filter problem
Old Aug 7, 2007 | 03:34 PM
dtm0768's Avatar
dtm0768
oil filter problem
i have a 302 from a 96' the oil filter has a through bolt that has holes in it. i cant figure it out. oil cooler? i was given the bottom end its for a my 1978 f 100 but i need a filter to finish. i was told it is a H/O but i just dont know
Old Aug 7, 2007 | 03:41 PM
Kemicalburns's Avatar
Kemicalburns
can you post a pic
Old Aug 7, 2007 | 03:43 PM
dtm0768's Avatar
dtm0768
the block has the female end the bolt is hollow about 3/4 in dia. long as a filiter should be
Old Aug 7, 2007 | 06:32 PM
HemiEater's Avatar
HemiEater
that's long for a cooler adaptor, but you never know. Head to a scrap yard and get one from a block kicking around any 302 351W 300/6 to name a few will have the right nipple.
Old Aug 8, 2007 | 10:18 PM
baddad457's Avatar
baddad457
The Explorer/Mountaineers had an angle adapter between the block and filter that used a hollow bolt. The 90's 351W's in the pickups and vans had a oil cooler adapter that also used the hollow bolt. The Explorer/Mountaineer adapter used the newer metric Ford oil filter where the Windsor oil cooler used the old FL-1A filter.
Todd Fuller
15
Oct 28, 2014 12:26 PM
cubman61
Modular V10 (6.8l)
25
Dec 6, 2012 11:55 AM
bigbubba87
Oct 31, 2010 11:37 PM
F3Beam
Feb 4, 2009 06:01 AM
lazyscholar
17
Mar 13, 2008 10:39 PM
