351W fuel pump lines
Old Aug 9, 2007 | 04:56 PM
Woodsman_30350's Avatar
Woodsman_30350
I have a stock mechanical fuel pump on my 351W. There are two ports off the pump. The one closest to the radiator is threaded and the other is a nipple pointing toward the driver. Which is inlet and which is outlet (to carb)? Also, will 3/8" fuel line be okay?
Old Aug 9, 2007 | 07:30 PM
HemiEater's Avatar
HemiEater
put your finger over them and turn it over...............
Old Aug 9, 2007 | 08:19 PM
51dueller's Avatar
51dueller
The threaded one is normally the output.
Old Aug 10, 2007 | 12:53 AM
Beanscoot's Avatar
Beanscoot
The nipple connects to a flexible hose to the fuel line that goes back to the gas tank. The threaded fitting is for a 5/16" fuel line that goes to the carburettor. A 3/8" line uses larger inverse flare nuts so won't fit the stock fuel pump and possibly not the carburettor depending on its connection style.
Bronco Billy
Sep 19, 2014 01:09 AM
madtrashman
25
Dec 24, 2013 03:20 PM
bremen242
Offroad & 4x4
Oct 17, 2004 02:28 PM
Hwy2Hell
Sep 24, 2004 08:11 AM
joners
Aug 12, 2003 08:08 PM
