Tru cool
Old Aug 7, 2007 | 01:32 PM
tndiesel's Avatar
tndiesel
Tru cool
Is there any auto parts stores that carry the Tru Cool 4379? I think that is the right part # for the 40K model? If not where the cheapest place to buy one?
Old Aug 7, 2007 | 01:41 PM
Pest007's Avatar
Pest007
I can't remember if it was a tru-cool brand, but Checker had the 40k model that I got
Old Aug 7, 2007 | 02:24 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Check this links:
http://www.importperformancetrans.com/coolers.shtml#main
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Cod e=tru-cool-hd
I hope it helps.
Old Aug 7, 2007 | 03:29 PM
tndiesel's Avatar
tndiesel
I meant local stores like autozone etc. so I didn't have to order it online.
Old Aug 7, 2007 | 03:36 PM
Cuda_jim's Avatar
Cuda_jim
You could try a hotrod shop, they usually carry an asortment of coolers. Most mega-auto part stores (AZ ect) don;t carry them around here. Some of the independant guys do though.
Old Aug 7, 2007 | 03:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Sorry, but why you dont want to order online?
Old Aug 7, 2007 | 06:08 PM
tndiesel's Avatar
tndiesel
So I could get it tomorrow and install it. Also easier if I need to take it back.
Old Aug 7, 2007 | 06:18 PM
Suber's Avatar
Suber
I dont think you will have very much luck finding it locally. I looked around in my town and the only thing that was available was Hayden coolers. The sooner you push the buy button, the sooner it will get to your house!
Old Aug 7, 2007 | 09:27 PM
Neal 97 250's Avatar
Neal 97 250
Seriously buy online you can return if necessary but you won't have to.
Old Aug 7, 2007 | 10:19 PM
Flea's Avatar
Flea
I love my new one. I don't have gauges yet but after running down the highway for a while I pulled over last night and the return line I could hold my hand around for a while. The to line was hot as hell.
Old Aug 8, 2007 | 06:58 AM
tndiesel's Avatar
tndiesel
I'm trying to decide if I need the bypass valve or not. Let me make sure I understand what it's for. When the outside temp. gets cold enough the tranny fluid will bypass your tranny cooler until it gets to certain temp then start flowing through tranny cooler to obtain proper operating temp.? Is that about right? Also, what is considered outside cold enough temp to need the bypass? I live in middle Tn. and it can get cold here but never really for very long. We do have days where it will be in lower to mid teens in early mornings.
Old Aug 8, 2007 | 02:34 PM
Flea's Avatar
Flea
I believe the instructions say 32deg. F. or lower needs a bypass valve. This leads me to believe that I can take it out of the radiator all together?
The tranny will create its own heat and will then open up the bypass valve in the winter time.
What do you all think?
Old Aug 8, 2007 | 03:04 PM
Cuda_jim's Avatar
Cuda_jim
I kinda like the idea of regulating the tranny temp. Having a thermostat (Thermal Break) does just that. I'm not expert but i believe that the clearances in the tranny were designed to work at a certain temp, what ever that is. Without the thermostat the tranny just runs at what ever the ambient temperature is cooling it. Running it though the radiator helps the tranny get up to temp quickly and the thermostat helps it maintain it. There is such a thing as running the tranny too cold I imagine, just like the engine. Have you ever seen the inside of an engine that was run with a stuck or no thermostat, the oil gets milky from condensation. My 10 cents with 8 cents change.
BENG0924
31
Jul 29, 2009 08:52 PM
03F2507.3
28
Jul 15, 2008 09:08 AM
HOTFOOT
May 3, 2006 04:27 PM
PSD Bill
13
Oct 25, 2005 12:13 PM
