Tru-cool without stock cooler??
Old Jul 12, 2008 | 02:00 PM
03F2507.3's Avatar
03F2507.3
I have an aftermarket trans cooler of some kind. Im not happy with my temps and want to get them lower. The 6.0 cooler is a great option but for $300 its a little pricey. Every post Ive read states the tru-cool is put in sequence with the stock cooler. Since I dont have a stock cooler I was going to remove the aftermarket cooler thats in there now and have only the tru-cool. Is this a good option? Does the install kit from dieselsite come with the parts I would need? Would I get enough cooling with ONLY a tru-cool 4739MAX?
Old Jul 12, 2008 | 02:34 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Cant help you with your question but here is a stock 7.3 trans cooler cheap
eBay Motors: FORD SUPERDUTY TRANSMISSION OIL COOLER 7.3 (item 360069165410 end time Jul-16-08 17:50:04 PDT)
Old Jul 12, 2008 | 02:41 PM
03F2507.3's Avatar
03F2507.3
Thanks, if I have to buy it I will. But I was hoping to just install a tru-cool...
Old Jul 12, 2008 | 02:56 PM
clintbonnie's Avatar
clintbonnie
I would just add the tru cool along with your aftermarket one..
Old Jul 12, 2008 | 02:59 PM
03F2507.3's Avatar
03F2507.3
Will I have too slow of a flow??
Im not sure the brand of aftermarket cooler?
Old Jul 12, 2008 | 10:47 PM
mueckster's Avatar
mueckster
Is the aftermarket cooler mounted in place of the stock cooler between the a/c condenser and intercooler? The TruCool is considered an "low pressure drop" cooler, IIRC, and should not be restrictive in mounted in a series with other coolers.
Old Jul 12, 2008 | 10:49 PM
03F2507.3's Avatar
03F2507.3
The current aftermarket cooler is mounted on the front of the a/c condenser. I would like to remove that one and use the tru-cool.
Old Jul 12, 2008 | 11:11 PM
mueckster's Avatar
mueckster
Then, you should already have the stock cooler in the radiator and the stock oil-to-air trans cooler behind the condenser. It would be a simple swap of the aftermarket one, up front, with the TruCool. This is what I have now. Works great.
Old Jul 12, 2008 | 11:28 PM
TP83's Avatar
TP83
pick up the v10 and tru cool and swap out the existing system and you should never have high tranny temps after that.
Old Jul 13, 2008 | 05:16 AM
ron's power stroke's Avatar
ron's power stroke
that sounds like the power steering cooler...fallow the lines back..where do they go??
Old Jul 13, 2008 | 09:12 AM
03F2507.3's Avatar
03F2507.3
No, the power steering cooler is tiny...besides I just did a flush on it and had it unhooked.
It is definately a trans cooler. I am not familiar with 2 trans coolers that seem to be mentioned here?? I assumed there was only one?
Old Jul 13, 2008 | 09:26 AM
MikeSDK's Avatar
MikeSDK
Running the Tru-Cool alone is how I am set up now. I wanted to compare temps between the stock set up, and the TruCool alone. My test was towing my travel trailer to Destin FL on vacation and back to TN.
Last year using the stock set-up only, temps got as high as roughly 195-197 degrees. Thats towing, fully loaded, 100* degrees ambient temp. This year running the Tru-Cool only and under essentially identical conditions, the highest trans temp I saw was about 175-177.
So, pretty good. That being said, I am still going to go back and re-route the lines so that I run the TruCool inline with the stock set-up, just to push it down a few more degrees.
And yes, the Powerstroke kit that Dieselsite offers is useful.
Hope that helps.
Old Jul 13, 2008 | 09:38 AM
clux's Avatar
clux
There is a stock oil to water cooler in the end of the radiator, and a stock oil to air cooler between the AC condenser and the charge air cooler. If it is in front of the condenser, it is definitely an aftermarket cooler.
Old Jul 13, 2008 | 10:08 AM
03F2507.3's Avatar
03F2507.3
Does anyone have pics or can you describe to me what to look for for the oil to water and air to water? Im not exactly sure what youre talking about?
Old Jul 13, 2008 | 10:40 AM
cangim's Avatar
cangim
If you don't have anything yet, I'd just watch for a 6.0 cooler to pop up on ebay, sometimes they go for a reasonable price. Or just go with two 4739 coolers up front and be done with it.
