Headlight relay kit
Old Aug 7, 2007 | 12:24 AM
geo455's Avatar
geo455
Headlight relay kit
Just wondering if anyone here has installed the headlight relay kit that is offered from LMC Truck. Is it worth the trouble? Or even necessary?
Thanks,
John
94 F-150 s/cab 5.8/E4OD 3.55LS 2wd
Old Aug 7, 2007 | 12:47 AM
nighthawk285's Avatar
nighthawk285
which kit in particular, do you have a link?
Old Aug 7, 2007 | 12:53 AM
geo455's Avatar
geo455
It's the heavy-duty headlight harness
http://www.lmctruck.com/icatalog/fd/t.asp?page=62
Old Aug 7, 2007 | 12:56 AM
nighthawk285
I don't know of anybody using this particular kit, but I have heard of a lot of people doing this mod from scratch and having good success. The kit would be nice to make things easier
Old Nov 30, 2008 | 10:13 PM
TheCamel's Avatar
TheCamel
LMC Headlight Relay Kit
I just installed this on my 89 F350. Plug and play installation. The instructions are somewhat hard to read (language translation), but following the diagram made it easy. Works great!
Old Nov 30, 2008 | 10:36 PM
MustangMatt96GT's Avatar
MustangMatt96GT
What is the point of the Harness? just that the stock one fries?
Old Nov 30, 2008 | 10:41 PM
95F350XL's Avatar
95F350XL
It lets the bulbs get the full 12-13v vs 10. Stock harness has resistance and uses some volts up.
Old Nov 30, 2008 | 11:25 PM
jonwoos's Avatar
jonwoos
Exactly true, and if you run higher wattage bulbs like I did , and burn up 2 switches, then you will want the harness. I have it on 2 of my 3 trucks at the moment. Probably put it on the other later, but the 88 F150 has a different style switch, so it might be better than the 92-up switches.
Old Nov 30, 2008 | 11:35 PM
goodB0Y's Avatar
goodB0Y
what is the harnes? larger gauge wires? I've been thinkin about doin the same mod but doing it my self
Old Dec 1, 2008 | 05:02 AM
jonwoos's Avatar
jonwoos
It is a set relays that hook directly to the battery +post at the starter relay, and then feed directly to the headlight bulbs with fusible links, and larger wire. The orginal switch in the dash, just turns the relays off, or on only. Relays use very little power, so no more bad switches, or burnt wiring harness pigtails.
Old Dec 1, 2008 | 05:48 AM
1Fastang's Avatar
1Fastang
I have a related question, I just did the 3G 130a swap, if there is roughly a 2 volt drop wouldnt the new altrnator help boost the voltage to the headlights a bit?
Old Dec 1, 2008 | 06:13 AM
jonwoos's Avatar
jonwoos
That would be only under heavy electrical loads like e-fans, stereo's or etc. for the amp draw. The voltage is suppose to be the same thru out the system, but wiring size, connections, and length cause it to lower. So, there will be a difference in volts from the battery to reading the light bulb voltage thru the stock wiring harness.
Old Dec 1, 2008 | 11:16 AM
quaddriver's Avatar
quaddriver
curious - is this the kit to turn on the lows when the brights are on (like chevys for example)? if so, Id avoid it cuz having both filaments on in your 9000 series bulb will melt it - literally.
(I used the brights+lows 'kit' on my k2500 by making it myself - 20A breaker, some wires, shrink tubing and a relay - about $8 my cost.)
Old Dec 1, 2008 | 11:35 AM
jonwoos's Avatar
jonwoos
Nope, works just like stock. High only, or low only.
Old Dec 1, 2008 | 06:49 PM
goodB0Y's Avatar
goodB0Y
I was going to do the same mod but use the old harness... now I'm thinking using thicker gauge wire is probably a good idea... from what I've seen you could build your own " kit " allot cheaper than buying the one from lmc
