BIG Problem
Old Aug 6, 2007 | 10:40 PM
mort13's Avatar
mort13
BIG Problem
I have a 1996 Ford Ranger 2.3L. When I start my car and start driving intially and I exceed 3000 rpms and then come to a complete stop, the car sounds like its going to die because the rpms goes to 500 rpms and starts to shake when it is suppose to be at 1000-1500 rpms when idling at a stop and then after a few seconds it starts iidling at 1000-1500 rpms again. The only check engine light to go on was "misfire" but I just changed my spark plugs and wires a few months ago and it did not have this problem before. I also replaced my whole block and pistons and everything, so I know it is not compression lost. When I have been driving after a while and the engine is warmed up it does not have this problem when I stop.
Whats the problem?
Old Aug 7, 2007 | 04:43 AM
Rockledge's Avatar
Rockledge
When did you get the misfire code? Before or after changing the plugs?
Assuming it's not an ignition issue, then I'd say you are looking at a bad IAC.
Old Aug 7, 2007 | 11:01 AM
mort13's Avatar
mort13
I received the misfire code after changing the plugs but not for a few months
Old Aug 7, 2007 | 11:04 AM
mort13's Avatar
mort13
may I should check the IAC valve, where is it located?
Old Aug 7, 2007 | 11:54 AM
Rockledge's Avatar
Rockledge
The IAC is mounted on the upper intake near the throttle body. Should look something like this:
Check out: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
EXv10
Modular V10 (6.8l)
32
Dec 29, 2013 10:34 AM
usaf_yz426
Jul 22, 2013 03:37 PM
busch6062
Jan 7, 2013 10:28 AM
Kanglar
Oct 14, 2011 03:05 PM
bamaf150
May 10, 2010 07:40 AM
