Door buzzer
Old Aug 5, 2007 | 01:09 PM
southern250's Avatar
southern250
Door buzzer
Someone told me a long time ago how to silence the annoying door dinger on my 06 250. Something about some wires under the steering column. Anyway, does anyone know what I have to do to silence that annoying dinger while leaving the key in the ignition?
Old Aug 5, 2007 | 01:49 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
https://www.ford-trucks.com/forums/4...oor-chime.html
you'll find your answer on this forum
Old Aug 5, 2007 | 04:35 PM
oddjobs2do's Avatar
oddjobs2do
Will this work on a 2003 F-250 6.0L?
How about a 1999 f-350 Utility bed 7.3L?
Thank Goodness you can shut that thing off..I dug around for the buzzer and it is attached somehow the the back of the fuse box and that silver box (whatever that is) behind the fuses on my 1999...but I'd like to do it to both trucks....
And trying to get the sequence for the seatbelt chime since I dont have a manual...
Old Aug 5, 2007 | 05:48 PM
bigredtruckmi
Veteran: Navy
It should work on the 03. The 99 doubfull.
Old Aug 7, 2007 | 05:46 PM
Beerstalker's Avatar
Beerstalker
This is the thread linked to by the Super Duty Tech Folder. It has the instructions to shut off the belt minder and the key in ignition chimes.
https://www.ford-trucks.com/forums/567156-beeper.html
The key in ignition chime disable procedure that I posted pictures of worked in both my 99 f250 and my 07 f350. For the 08s I posted a quote from another user on here about how he was able to do it.
OldschoolBoy
Nov 28, 2016 11:20 PM
jerseymike
May 5, 2016 11:10 PM
xluckyxbulletsx
Aug 13, 2009 02:35 PM
ejstith
May 8, 2005 10:43 AM
redbull660
Jun 30, 2004 11:27 PM
