Door dinger keeps dinging
Old May 7, 2005 | 07:36 AM
ejstith's Avatar
ejstith
Question Door dinger keeps dinging
'97 Explorer XLT. When I take the key out, lights off and open the driver door the dinger keeps dinging. It doesn't have a "normal" button to activate the system, there is a cylinder thingy at the forward edge of the door that apparently controls the system. Question: How do I fix it? Or how do I disconnect the dinger?
Old May 7, 2005 | 10:49 AM
marragtop's Avatar
marragtop
Are your interior lights staying on as well?
Old May 7, 2005 | 12:21 PM
ejstith's Avatar
ejstith
No nothing else happens but the door dinger. I'll just pull the plug on it if I can find it.
Old May 8, 2005 | 10:43 AM
Dialtone's Avatar
Dialtone
Not sure how the 97 is designed, but I can tell you that on the 91-95's, there is a micro-switch in the key cylinder housing that activates the chimer when key is in the switch and door is opened. This switch has a small plastic tip that rides on the edge of the key and operates the switch contacts. The plastic is prone to breaking off over time and usage, and can jam in the contacts (as well as in the key cylinder itself). The only fix is to R&R the switch assembly which means pulling the steering wheel and exposing the cylinder mechanism.
If this it the ONLY problem you have, it is probably not worth the hassle unless you are REALLY annoyed by the chime.
On the early models, the chime mechanism is under the dash in the vacinity of the ashtray. You can simply disconnect the wiring harness to it to stop the chime.
Dialtone
ryaneverk2
Sep 14, 2021 09:57 AM
OldschoolBoy
Nov 28, 2016 11:20 PM
jhutche
Sep 23, 2005 02:35 PM
redbull660
Jun 30, 2004 11:27 PM
TXBDBY
Jan 20, 2004 05:56 PM
