Sponsored by: Auxito
Tire Question
Old Aug 5, 2007 | 10:15 AM
Black97F150v6's Avatar
Black97F150v6
Tire Question
I have a 2 Wheel drive 1997 Ford F150 XLT 4.2 L..I currently have 265/70/16 tires on my Vehicle. The only problem is they are typical street/ touring tires that we purchased for real cheap. I was wondering what the maximum size tire is I can put on them, without getting any sort of lift. I was looking into some All Terrain tires. Thanks for the help!!
Old Aug 5, 2007 | 09:25 PM
MBBFord's Avatar
MBBFord
Since you only have a V6, you might not want to go bigger than 265s, but either way, the maximum tire size you can fit would be 285/75R16, but that would be pushing it with a 2wd.
Old Aug 5, 2007 | 09:49 PM
galaxie641's Avatar
galaxie641
I am pretty sure 265/70/17's are as large as you can go on a 2wd without any rubbing problems. 285/70/17's (33's) are as big as you can go on a 4wd, so they will definitely rub on a 2wd.
Old Aug 5, 2007 | 10:00 PM
MBBFord's Avatar
MBBFord
I've seen people with 285s on a 2wd before, but don't know how much rubbing they have, which is why I said it'd be pushing it.
Plus gas mileage would suck, and so would acceleration.
Old Aug 5, 2007 | 10:48 PM
tj90's Avatar
tj90
I have 265/75r16 and love them. Been running the Definity (Pep Boys Cooper) Dakota ATs and actually like them pretty well. Not too much road noise and make the truck looks more aggressive. Buy 3 and get the 4th free right now promotion. Plus, made in the USA - hard to find at <$100 per tire (<$75/per tire with sale). I have a 2wd 97 with the 4.6 V8. I also have the tow package with the 3.55 rear end, so I dont know how they would be with a V6 and standard gears. The 75 series give you much more sidewall than the 70 series so the tire is larger and "proportioned" (filling the wheel wells well) IMO. did not notice any significant drop in mileage - ~14-16 mpg from day 1... Im not even close to rubbing these tires.
You also cant go wrong with the BFG ALL Terrain TAs. They have an D load rating so they are stiffer than the stadard load rating, but not E load rated "hard as rock" sidewalls.
If you are unsure with acceleration, gas mileage, fit some used tires with the size you are looking for and drive it around for a couple weeks. This way you know what you are in for before commiting big money on new tires. In my area, you can find used tires for $10. Only get 2 of them - fit on rear for accelration power tests and then swap to front to check clearance.
Old Aug 5, 2007 | 11:06 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My truck will fit 34's with no trimming...I've done a test fit with a friends set of nearly-bald 35's that measured out to 34". It's completely stock too.
But back on topic, I have seen 33" on a 2WD with minor trimming of the air dam. That would be pushing it with a V6 though....My 4.6 has a hard time with my 33's
Old Aug 6, 2007 | 07:03 AM
Black97F150v6
Thanks for your help every1, you just basically made my decision lol
Old Aug 9, 2007 | 12:58 PM
B's FX4's Avatar
B's FX4
i run 33's or 285's i put some pics in my profile check em out!
Redneckfordf2502002
Sep 28, 2012 02:31 PM
StumpPullerF1
48
Jan 30, 2011 11:27 PM
Cornraker
2004 - 2008 F150
Sep 28, 2010 12:26 PM
SasquatchF-250
Dec 9, 2009 09:46 PM
dcypert1
2004 - 2008 F150
May 16, 2009 09:42 PM
