I'm finally ready to go turbo so I'm looking at 2 options. Banks complete system or Hypermax Pulse system plus intercooler.
I'm hoping guys out there with the intercooler can chime in.
I figure the money I save on not using Banks will go towards the intercooler, since I already have gauges and exhuast.
Dyno results would be great if available.
FYI: 87 CC Dually 6.9L C-6 (140K on motor) I tow trailers ranging from 16' tandemflat to a 35' 5th wheel triaxle on occassion and DD during the week.
the general consensus is that with the low boost supplied by the turbo on an IDI engine, the cost to power increase of an intercooler is not worth it.
basically put, an intercooler does not do anything with boost levels under 10 lbs, and the max boost you can expect to see will only be about 10 lbs. so for the added cost of the cooler, it just isn't worth it.
I never heard of that. Cooling the incoming air wether it's turboed or not increases HP. Hypermax claims 30% added power, I'd like to hear some real testimonials or dyno runs.
you used the magic word. hypermax CLAIMS a 30% increase in power.
they will say anything to make the sale. just because it is not true means nothing.
you can expect to see a 30% increase in power with the turbo and increasing the fuel flow rate. not with the intercooler.
The key words that you need to be aware of are "up to 30%". The unit will only make at most 10 pounds and I was blowing coal out the exhaust at the time. Don't waste the money on an intercooler. I have a standard Hypermax on my truck and it works just fine. I would take the money for the intercooler and use it to get better injectors and or a new pump.
Thanks I appreciate your reply. Due to the fact you can only get 10psi out of it, if you had the chance would you now go with the banks with the adjustable wastegate to get more boost around 13psi?
Intercoolers can make a huge difference. When they started intercoolers or aftercollers on big engines is when they started making alot more power. There is a big difference between cooled air going into a motor then hot air. If you can get your intake temps down in the mid 100's from the high 200's to 300's you are doing good. They give you more volumn of compressed intake air. The cooler the air the more dense it is which means more oxygen.
You will make more power with 10 lbs. of cool air then 13 lbs of hot air.
the idi engine can only safely handle around 15 lbs of boost before it starts stretching head bolts, blowing by the rings and in general doing real nasty things to the engine.
remember, these things were designed to be run without a turbo. turbo engines are built different. with stronger head bolts and lower compression being just two items to consider.
yes, you are 100% correct.
that is not what i am saying though.
what i am saying is that for the cost of an intercooler, which normally runs around $900, you can do allot better things to get more power than the intercooler will give you.
On a wrecker we have at our shop...
We're currently running a 7.3 PSD intercooler, did it this weekend, and lost only a half pound (from 13 psi to 12.5). Dropped pre-intake temp 300 degrees and lowered EGT's by about 200.
All comments are considered but this quote above is exactly the kind of information, not assumption, that I'm looking for. Real experience with #'s to back it. Hp readings before/after would be great too.(I know I want everything)
I'm not concerned about price per pony, I know I'm limited on what I can do to get the most power from an idi without tear down. My thing is I already have the Banks Stinger system which came w/ exhaust and pyro (also already have boost gauge). So going with Hypermax I'm saving about $1000 on things I already have, which in turn could go towards the intercooler. Know see my position?
I wasn't disagreeing with you but I see wear you are coming from if a person was going to give that much for an air to air. A person could build a system theirselves alot cheaper. I run into air to airs off of pick-ups and other light duty trucks all of the time for alittle of nothing. Piping wouldn't be hard either. I am going to put one on my trucks when I get time.
87 getting actual numbers from somebody other then a saleman might be kinda hard. Not everybody has a dino.
