Flywheel Question
Old Aug 4, 2007 | 01:10 PM
nzabka's Avatar
nzabka
Flywheel Question
I recently acquired a flywheel but am not sure which weight it is.
Casting# is: E7ZR-6380-AA
I want to stick it in my '67 289 but want to be sure the imbalance is correct.
Thank You!
Old Aug 4, 2007 | 07:17 PM
DaveBB's Avatar
DaveBB
Does this help?
http://www.geocities.com/cping3/late302.html
Old Aug 4, 2007 | 08:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Casting# is: E7ZR-6380-AA=1987 Mustang / it uses a different vibration damper than the 1967 289 does.
Thank You!
If your 289 has the original damper, only ONE of these two flywheels is correct.
1965/67 289 = C3AZ-6375-J .. Flywheel-M/T = marked: C6ZE-6380-A or B & C7ZE-6375-B - OBSOLETE
1965/67 289 = C3AZ-6375-L .. Flywheel-C-4 = marked: C80P-C or D -STILL AVAILABLE FROM FORD.
C3AZ-J (157 teeth) = Manual transmission was also used on 302's from 1971/78
C3AZ-L (157 teeth) = C-4 was also used on 302's from 1968/76.
Old Aug 6, 2007 | 08:23 AM
nzabka's Avatar
nzabka
Thanks. I'm converting my 67 mustang from a auto to a manual. I've found someone who can balance this flywheel to match the c4 flexplate of 28 oz. that I removed.
Old Aug 8, 2007 | 08:24 AM
nzabka's Avatar
nzabka
One more question, will the 87 mustang flywheel have the same number of teeth as the 67?
(I know, count them my self but I'm not able to do this for a couple of days)
Thanks guys.
Greg Shea
Jun 7, 2017 11:46 PM
GOOG
Mar 9, 2016 10:14 PM
Jaime74656
Dec 17, 2015 10:23 PM
1Archerman
Dec 17, 2009 01:08 PM
rosentr
Feb 21, 2003 10:35 AM
