guys need some help decoding vin data plate: F25YRH18961 BELOW THAT READS: 131 D F254 434 G 24 BELOW THAT READS: 06900 170 4100 73 SHOULD BE A 1970. THANKS!
F25 = F250 2WD
Y = 360 2V
R = San Jose Assembly Plant
H18691 = 1970
131 = 131" Wheelbase
D = Pinto Yellow (aka Light Gold)
F254 = 1970 F250 2WD / 6900 lbs. GVWR
43 = Charcoal Black Kiwi Vinyl / Charcoal Black Diamond Basketweave Vinyl
4 = 81A Standard Cab
G = C-6 Cruise-O-Matic
24 = Dana 60 / 4.10-1 / Non Limited Slip / 5200 lb. Rear Axle Capacity
06900 = 6900 lbs. GVWR
170 HP @ 4100 RPM
73 = Salt Lake City Ford District Sales Zone
Info source: 1964/72 Ford Truck Parts Catalog - General Information Section - VIN Decodes / Paint Section / Rear Axle Section 40 / Soft Trim Section
