Need help decoding the vin and door plate
Old Jun 28, 2013 | 01:26 AM
Williamkwebn's Avatar
Williamkwebn
Need help decoding my 66 f100 Vin and door plate
The vin is f10bn874966
The door numbers below
115 HH F100 081 C08
05000 150 3600 24
Help is greatly appreciated
Old Jun 28, 2013 | 05:27 AM
jowilker's Avatar
jowilker
Williamkwebn, Welcome to FTE & the Slicks Forum.
I lost my access to that info with a hard drive crash, but Mr. Wilson or anutter member will be along shortly to lay it all out for you. I am going to stick my neck out from memory and say F100, 240 6 banger built in Norfolk. I'll sit by and see how far off I am.
John
Old Jun 28, 2013 | 09:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Williamkwebn
Need help decoding my 66 F100 VIN and Warranty Plate.
F10BN874966 // W.B. 115 / COLOR: HM / MODEL: F100 / BODY: D81 / TRANS: C / AXLE: 08 / MAX GVW LBS: 05000 / CERT NET HP: 150 / RPM: 3600 / DSO: 24
Welcome to FTE
F10 = F100 2WD
B = 300 1V I-6.
N = Norfolk VA Assembly Plant.
874966 = 1966, assembled June 1966.
115" Wheelbase.
HM: H = Sahara Beige / M = Wimbledon White.
F100 2WD, 5,000 lbs. GVWR
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
24 = Jacksonville FL Ford District Sales Office, where the original selling dealer ordered the truck from.
Last edited by NumberDummy; Jun 28, 2013 at 11:41 AM. Reason: Edited in correct codes for COLOR & BODY.
Old Jun 28, 2013 | 10:55 AM
Williamkwebn
Welcome to FTE
F10 = F100 2WD
B = 300 1V I-6.
115" Wheelbase.
HH = Cannot be HH as two codes represent tu-tone paint. H = Sahara Beige. If tu-tone, H followed by a different letter or a number.
0 81: Cannot be 0 or the letter O. it's probably a C or D. Will decode when corrected.
Got it. Thank you for a that. The correction is HM and D81
Old Jun 28, 2013 | 11:39 AM
NumberDummy
Correct codes edited into post 3 and decoded.
Argie66
Dec 11, 2014 09:36 PM
kjvforme
21
Feb 12, 2014 01:17 PM
breedo99
Jan 28, 2014 08:40 PM
dads1966
Sep 1, 2013 01:30 AM
kevin206
May 25, 2010 11:39 PM
