Sponsored by: Real Truck
confused
Old Aug 3, 2007 | 10:16 PM
hefmo's Avatar
hefmo
confused
Have A 2003 F250 7.3l At Different Times When Truck Is Running And I'm Driving The Radio,power Windows And Dome Lights Quit Working, Then Suddenly They Just Come On. This May Happen Everyday Or Once A Week,could This Be The Door Sensor Or Where Would I Start. Thanks So Much
Old Aug 4, 2007 | 05:05 AM
ken kenmnedy's Avatar
ken kenmnedy
sounds like your loseing your grounds some where big time DC current needs complete cercit + to - or seystem wont work
Old Aug 4, 2007 | 09:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Does your dome light come on when this happens?
Old Aug 4, 2007 | 12:49 PM
hefmo's Avatar
hefmo
the center [dome light] works but the side lamps of the dome does not.
Old Aug 4, 2007 | 08:57 PM
DaveBB's Avatar
DaveBB
Sounds like a hard one. I wonder if it could be that your key isn't returning all the way to run everytime.
Dave.
Old Aug 4, 2007 | 10:18 PM
hefmo's Avatar
hefmo
which is funny,because these are the same things--radio,windows,and light that operate on these trucks after key is turned off from run for 5 minutes.
Old Aug 4, 2007 | 10:36 PM
DaveBB's Avatar
DaveBB
So the next thing may be to find the timer/relay that does the 5 minute thing. It's probably under the hood under the cover for the maxi fuzes. There may be a bad connection there somewhere.
Old Aug 5, 2007 | 06:15 AM
msgtg's Avatar
msgtg
Hefmo, welcome to the site Pal. Lots of good info to be learned here!
Ok, on to your issue. I too have an 03 crew but mines got the 6.0 in it. I too have a delay (once the key is off) that allows you to raise/lower your windows and the radio will continue to play UNTIL you open a door. At that point everything powers down. This is a normal courtesy feature.
Now, if yours continues even after the door is open, then you have an electrical issue.
Ken mentioned the ground issue...I concur. It's a bit of work but you need to trace this one down.
Good Luck!
Joe
Old Aug 5, 2007 | 06:53 AM
hefmo's Avatar
hefmo
Hi Joe, my promblem is that my radio and windows power off while driving then they just power back up while driving, so electric delay or door sensor promblem is where I will start. thanks
Old Aug 5, 2007 | 10:51 AM
DaveBB's Avatar
DaveBB
I'm thinking that the door switch or sensor is probably not in the loop with the key on run. You can usually open the door with the key on and the radio still plays.
Joe's thinking is great to follow too. could be a common ground for the systems affected. The manual should lead you there. You may need to get one.
Dave.
Old Aug 5, 2007 | 11:50 AM
Beerstalker's Avatar
Beerstalker
I believe there was a TSB about some trucks having the fuses installed incorrectly, which causes intermittant power losses. You may want to check all your fuses and make sure they are insalled correctly.
Old Aug 5, 2007 | 02:31 PM
ayden2004's Avatar
ayden2004
are you still running the original radio. I have seen a lot of aftermarket radios installed wrong. can cause everything from a blown fuse to suddenly having your marker lights on all the time while the truck is running. if its aftermarket pull the radio and check connections. if you have a bad splice it could be shorting everything out.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
