Duraspark II Question
Old Nov 6, 2012 | 08:06 PM
68cabby's Avatar
68cabby
Hey guys, quick question about the years of the Duraspark II. I found a whole setup from an 86 f150 with a 300..it just says "duraspark" but was wondering if this is a duraspark 2? What is the difference anyways?
Old Nov 6, 2012 | 11:35 PM
fordman75's Avatar
fordman75
86 wouldn't be a Duraspark. 86 would be TFI. DS II I believe would be from 77 or 78-82. So if that 86 has a DSII set up someone swapped it in.
If it has the large diameter flat distributor cap it's a Duraspark II. The ignition module will be mounted on the inner fender and will have a blue plastic piece where the wires come out of the ignition module.
A small diameter cap with a gray ignition module mounted on distributor is the TFI.
Old Nov 7, 2012 | 12:03 AM
68cabby's Avatar
68cabby
Ok..gotcha. it is in fact a ds2. I believe the engine HAD tfi..but I'm converting from a points system on a 68 while I swap in this engine
Old Nov 7, 2012 | 12:20 AM
fordman75's Avatar
fordman75
Just make sure to grab the distributor, coil, ignition module and wiring harness and you are good to go.
Old Nov 7, 2012 | 08:18 AM
68cabby's Avatar
68cabby
Everything comes with it!! That's why I'm excited haha
Old Nov 7, 2012 | 04:00 PM
fmc400's Avatar
fmc400
MSEE
Make sure this module is a BLUE-grommet module; other colors represent nonstandard emissions and altitude controls that aren't necessary for what you're doing and can cause issues.
Old Nov 7, 2012 | 05:46 PM
68cabby's Avatar
68cabby
Where is the grommet at?
Old Nov 7, 2012 | 05:47 PM
68cabby's Avatar
68cabby
Even if the engine is nonemissions and non feedback?
Old Nov 7, 2012 | 06:01 PM
fordman75's Avatar
fordman75
I mentioned it in one of my other replies. It's a plastic block deal where the wires come out of the ignition module. Blue is the most common color. But there are also yellow, brown, white, green, red and black.
Old Nov 7, 2012 | 06:34 PM
68cabby's Avatar
68cabby
If the truck is a non feedback type truck..would it matter?
Old Nov 7, 2012 | 06:37 PM
fordman75's Avatar
fordman75
Yes.
Certain modules require different voltage at the coil.
Old Nov 7, 2012 | 06:44 PM
68cabby's Avatar
68cabby
Hmm..never thought about that.
Old Nov 7, 2012 | 07:03 PM
68cabby's Avatar
68cabby
if it's not the right box, I have another that I can try. So the BLUE grommet is the one I want eh? I emailed the seller and asked, just waiting for the response. Any particular that blue is the magic color?
Old Nov 7, 2012 | 08:17 PM
68cabby's Avatar
68cabby
Ok..worries subsided. It is a blue grommet box. Phew!
Old Nov 7, 2012 | 09:01 PM
fmc400's Avatar
fmc400
MSEE
You are good to go.
The Frenchtown Flyer
May 7, 2016 09:36 AM
greentruck72
Feb 23, 2015 08:10 AM
raven3
Jul 22, 2014 09:45 AM
ol'bluef150
23
Mar 25, 2010 10:37 AM
Pick em up
Electrical Systems/Wiring
Sep 20, 2003 05:36 PM
