Changed ICP Sensor, 10K weaker?
Old Oct 9, 2007 | 04:50 PM
alstieg's Avatar
alstieg
o1PS where did you buy the ICP on ebay? got a link to the store? I might try buying and see if it works. My original leaks as well.
Old Oct 9, 2007 | 06:02 PM
puffen:D's Avatar
puffen:D
Is your resister bad?
Old Oct 9, 2007 | 07:39 PM
alstieg's Avatar
alstieg
mine? no, I don't think so. its all oily when I pull the plug off. is that bad?
Old Oct 9, 2007 | 10:16 PM
01PS's Avatar
01PS
Originally Posted by Bob Riley
Are you getting an SES light? Where you getting one before with the old sensor? Have you checked HPOP pressure at WOT?
I'll check back if you have more questions.
Bob
I was getting an SES light with the old sensor going up steep hills at WOT empty. It got more frequent towards the end. After the new sensor, I have yet to get an SES light.
I have not checked the HPOP pressure at WOT.
Can a bad ICP sensor jack with the trip confuser? Used to read 20mpg and around 16 (waaaay more realistic) with the new sensor.
How do I get my low end back. Like I said, it sounds healthier and shifts healthier but I'd like that zip back.
Old Oct 9, 2007 | 10:50 PM
01PS's Avatar
01PS
Can't recall the store, but I will check after work tomorrow.
Old Oct 10, 2007 | 04:04 AM
puffen:D's Avatar
puffen:D
Resistors can go bad, you can check it with an ohm meter, also make sure your connections are good and clean that can affect the resistance. Bad connection/bad resistor would make it run in the default mode.
Old Oct 13, 2007 | 12:27 PM
01PS's Avatar
01PS
So..... shouldn't I be able to unplug the harness and compare that with how it ran with the old sensor? How unreliable is the trip computer? It was reading 20+mpg before the sensor change. Thanks!!!!!
Devilmanak
Modular V10 (6.8l)
Mar 20, 2020 10:51 AM
WilPower
15
Dec 18, 2012 07:41 PM
rcrdps
29
Jul 1, 2012 06:17 PM
XBAJBUSX
21
May 27, 2010 07:08 AM
megawatt00
34
May 8, 2009 12:52 AM
