Ash Tray Spring
Old Aug 2, 2007 | 10:20 AM
dkoenig's Avatar
dkoenig
Ash Tray Spring
The spring that pushes the Ash Tray/Cup holder out on my 2000 expy popped off. It is not (to me) obvious how this goes back on, or if there was a clip that held it in place.
Does anybody have any ideas how this connects?
Thank you
Don
Old Aug 2, 2007 | 02:05 PM
buzzard's Avatar
buzzard
Mine came apart a few years ago after someone jammed something up into the cupholder. I pulled the whole thing apart and noted that a small piece on the spring retainer had broken. I don't recall exact fix, but whatever it was, it was very obvious and simple (even for someone as dense as I) and has worked for years.
Old Aug 2, 2007 | 03:17 PM
kailor's Avatar
kailor
It is actually a clip bent such that it acts like a spring. I don't recall the exact orientation (although pushing in lighty makes the tray want to spring back out, this should help in deciphering orientation). I drilled a small hole in my clip and screwed it to the backside of the tray and it has WORKED FLAWLESSLY ever since.
Old Aug 3, 2007 | 11:02 AM
buzzard's Avatar
buzzard
Now that kailor mentioned this, that's what I did too, drill a small hole and inserted a screw to hold things together.
mikecox1
Jul 9, 2009 03:28 PM
edmundo7
2004 - 2008 F150
Feb 7, 2008 02:26 PM
69ford99
1978 - 1996 Big Bronco
Jun 9, 2006 11:56 PM
