Steering Column
Old Oct 16, 1999 | 10:59 PM
frank_1's Avatar
frank_1
Steering Column
Anyone have any knowledge of the easiest steering column, that has tilt, that can be installed in a 1953 to 1956 pickup with power steering. Before I start this task I would like to get more information on possible used columns vs. a column from "ididit". Shifter is on the floor. Thanks
Old Oct 27, 1999 | 10:33 AM
rick's Avatar
rick
Steering Column
Frank,
I am rebuilding a 56 myself and would be interested as to what kind of power steering setup you are using
Old Oct 31, 1999 | 03:28 PM
Frank Grant
Guest
Posts: n/a
Steering Column
Right now I am planning to install a 1994 351W "Lightining" engine. This engine has a power steering unit on it now. The stock front steering system will be removed and changed to a Heidt IFS kit with disk brakes. Hope this helps.
Old Feb 7, 2000 | 12:00 AM
f100snoopy's Avatar
f100snoopy
Steering Column
I've been told the TOYOTA powersteering conversion is the best away to get better steering and the cheepest way if you plain to change the box and keep the streight axle.
I have a 56 F100 I'm workin on too.
If I can help drop me a line.
R L
f100snoopy(No Email Addresses In Posts!)
Old Feb 10, 2000 | 07:23 AM
DeenHylton's Avatar
DeenHylton
Steering Column
McDizzle
Sep 8, 2016 08:49 PM
Closenough
Jun 23, 2016 06:57 AM
dbyrd342
May 24, 2016 01:37 PM
Zellian
Bronco II
Oct 25, 2009 01:27 PM
73FOMO
13
Apr 11, 2006 11:48 AM
