Service Engine Soon
Old Aug 2, 2007 | 07:46 AM
scott7512's Avatar
scott7512
Service Engine Soon
I have an 03 expy with 110k it has been idling kinda rough and this morning when i started it the service engine soon light was on. Any ideas what this could be. I was planning on changing plugs soon could this be the problem or something else? Any help would be appreciated.
Old Aug 2, 2007 | 09:36 AM
04markIII's Avatar
04markIII
too many variables. could be cats too. make that appt soon. dont want to damage anything.
Old Aug 2, 2007 | 09:39 AM
SMIGGS's Avatar
SMIGGS
Scott,
Get the codes pulled and post them or do a search here and usually the diagnosis is spot on.
Old Aug 2, 2007 | 10:54 AM
scott7512's Avatar
scott7512
Thanks guys I will pull codes tonight and post in the morning.
Old Aug 2, 2007 | 07:31 PM
scott7512's Avatar
scott7512
Ok here is what codes are coming up. P1000, P1AEE, P0008. Tahnks in advance.
Old Aug 2, 2007 | 07:43 PM
Mark62's Avatar
Mark62
P1000 = OBD Systems Readiness Test not Complete
Old Aug 6, 2007 | 05:53 PM
JASON11WS6's Avatar
JASON11WS6
I've had a similar problem and was thinking tune up as well but it's getting much worse and the ses light kinda has me thinking cats too. Wish it was just a tune up, anyway I have a scanner and it isn't receiving any juice from the obd2 port. Bad news, so I can't even look up my codes. So my question would be is their anything I can do to see if it is the cats short of putting holes in them or ripping them off completly. Would hitting them with a hammer or something like that help out at all?
Old Aug 6, 2007 | 07:40 PM
projectSHO89's Avatar
projectSHO89
There's nothing wrong with your cats, yet. Forget that idea. Of course, if you don't fix the misfire, you will have dead cats...
98% likely you have a simple misfire. You just need to put a proper scan tool on it instead of that POS tuner. The last two of those "codes" are bogus....
As for the noob with a dead OBD-II port, you probably have a blown fuse that runs either the cigar lighter or the aux power port, depending on which year you have (which you didn't identify....).
There are dozens of posts in this and the 97-03 forum about how to figure it out. The engines are the same, everything applies.. Look especially for posts by jbrew or myself.
Steve
Old Aug 7, 2007 | 09:51 AM
JASON11WS6's Avatar
JASON11WS6
It's an 01 4.6 awd! I'll try and check through some fuses though. Good call.
John Hancock
Modular V8 (4.6L, 5.4L)
23
Jun 15, 2019 12:55 PM
Scott Scheele
1997 - 2003 F150
Jan 11, 2016 09:32 PM
bigfootmoses85
Sep 24, 2015 08:46 PM
RUMO
15
Apr 22, 2008 02:52 AM
Quick4.2L
3.8 & 4.2L V6
19
Feb 23, 2004 09:53 PM
