Service Engine Soon Light - Rough Idle
I started my 7.3L XLT today after about 3-4 weeks of non-use.
I noticed the Service Engine Soon Light came on and stayed on after the engine started. Initially, the motor seemed to run fine, but after letting it idle for a few minutes, it stalled.
I started it again (and again the Service Engine Soon Light came on and stayed on) and the idle was very rough! Turned it off, waited a few minutes, and the Service Engine Soon Light didn't come on, but, the engine idle was VERY rough??!!
The vehicle has been sitting in a warehouse, and used very infrequently over the last 9 - 12 months.
I checked the engine oil level - looked fine.
Any suggestions, advice would be greatly appreciated!
Welcome to FTE.
How many miles are on the oil? Clean full oil is a must for proper operation. There's a possibility you've got air in the oil rails that needs to work it's way out. How long did you let the truck run before you gave up?
You might also have bad fuel. Did you put in any kind of treatment before you let it sit? Generally diesel should be used within 6 months.
Were there any issues before you parked it?
Thanks for your suggestions.
There was no white smoke.
I'd just come back from a 200 mile round trip drive about 3 weeks prior, and it didn't miss a beat.
Didn't run it for very long at all initially - say 30 secs to 1 minute - after reading your posts, I started it up again this morning and ran it for about 5 mins and it seemed to get better - just the ocassional miss at idle, but ran well above 1500 RPM.
I'll drop the oil and change the filter, and see if my mechanic has got a tester that will "pull the codes".
I'm in Perth Western Australia, and the Ford Dealers here won't sell testers to anyone, and charge exhorbitant amounts to put a tester on a F250, and charge even more exhorbitantly if a sensor needs replacing (eg: $800 - $1200AUD)??!! Can anyone recommend a tester, and a reputable supplier where I can buy one over the internet?
Once again, thanks.
Once again, thanks.
Welcome to FTE Rumo. Most of us are fond of the Auto Enginuity scan tool. You will need the enhanced ford package to read the Powerstroke codes. The best place to get them is usually here: http://www.itpdiesel.com/store.php?c...on=show_detail
on
We put a tester on it and the code for a faulty ICP came up!!
Checked with local Ford 'stealers' and my Perth W. Australian price is $486.00 AUD!!
Any suggestions where I can best get a hold of 1/2 a dozen of these things over the web?
I've got 4 mates with F250's (which we use to pull fishing boats around), so I'm guessing that if my F250 needs a new ICP at 52,000 KMS that they may need them soon as well (all under 100,000 KMS).
(Ron, I don't know for sure if it's the ICP until I get a replacement one fitted up, but, I'm pretty sure that a new ICP will fix the problem - I will, ofcourse let you know one way or the other).
Thanks again for your replies and suggestions to date!!
Just thought I would let you guys know - as suggested elsewhere on this forum, I disconnected the wiring to the ICP and took the truck for a 20 minute drive and it didn't miss a beat!!
Is there a problem with running the truck with the ICP disconnected until I can source a reasonably price replacement (say 1 - 2 weeks)?
Any suggestions on where I can buy a few reasonably priced ICP's over the web would be much appreciated?
You can buy them here. But I don't know if they ship internationally.
http://catalog.powerstrokeshop.com/p...&subcat2=73147
For what it's worth, the old body style (94.5-97) powerstrokes have the same part #. Maybe you could luck out and find one in a junk yard or something. And really it's a 2 minute deal to change. If you don't have a junk yard, pm me. Texas may have something for you.
The ICP is a cheaper test...
RUMO....I picked up an ICP sensor on Ebay for about $50. A snap to change. If you can't find one that will ship to you I still have my old one I took out 2 weeks ago. I'm sure it still works ok.... I changed trying to find a way to cheaply chase/fix another problem. I wouldn't mind dropping it in the mail for you to at least try it if you can't find another...better than the $500 local dealer rip-off for sure.
