HELP: Question about Code 224 ?????
Old Aug 2, 2007 | 05:11 AM
meck1's Avatar
meck1
I just bought a '94 Ranger, 2.3L, five speed, and I'm going through it trying to figure out what I've got to do to it, etc. When I run the codes, I get one, a continuous code 224. The Haynes Manual for the truck says 224 is "Spout Circuit Open." The manual that came with the code reader says 224 is "Loss of IDM input to processor/Spout circuit ground/coil 1,2,3 or 4." The Haynes Techbook on Computer Codes says 224 is "PCM detected coil 1,2,3 or 4 primary circuit failure."
Can somebody tell me a more specific interpretation of this code 224? I don't want to tear into something/replace something without a clearer idea of what is going on. The only things I checked before posting this question was (1) to make sure the SPOUT plug was in and secure and (2) to make sure the coil packs were getting full voltage.
I'll appreciate any advice--
Old Aug 2, 2007 | 06:23 AM
Rockledge's Avatar
Rockledge
Code 224 means that some sort of improper firing of one of the coils was detected by the PCM. This is most often the result of either:
1. a bad coil;
2. a bad DIS module (which fires the coils and also is responsible for processing the IDM signal*) or
3. an open or short in one of the related circuits.
*The IDM signal is the "kickback" voltage that occurs when a coil fires.
Old Aug 3, 2007 | 05:04 AM
meck1's Avatar
meck1
Thanks for your very quick and clearly written reply. I'll check out the points you mention.
92Ranger123
Jun 13, 2014 04:17 PM
navag8ter
13
Oct 5, 2013 08:07 PM
clhart426
17
Jan 12, 2012 08:10 PM
earthquake68
26
Dec 30, 2011 02:28 AM
Lou58
Jan 14, 2011 08:40 PM
