I have a 2003 f-350 6.0 that doesn't pull very good from a dead stop. After you get going it does great. Any one know what I should check? I was turning around the other day and the front wheel ran of in a little ditch and the truck wouldn't even spin the tires.
These trucks produce their low end grunt a little higher in the rpm's than the 7.3L or the competition. They like to play in the higher rpm's. If it wouldnt do that then you may have a problem.
