Door Panel
Old Aug 2, 2007 | 01:26 AM
Pud12343's Avatar
Pud12343
Door Panel
Ok, how do you get the door panel on a '76 f100 off? i was outside looking for somethin in my truck and shined the flashlight towards my door.....and it caught my eye that there was something behind it....i have two speakers behind the panel taht arent hooked up lol....that i didnt know were there. so yea....dont know if they're supposed to be there or not, but im gonna put some good ones in there and see how that works
Old Aug 2, 2007 | 06:48 AM
ubereal2's Avatar
ubereal2
The door panel is held on by plastic clips attatched to the door, and are pushed into the door itself. A special tool (nothing expensive) is made that will pry the two apart. Or you can try a screwdriver to pry them apart. Just try not to damage if the panels are nice.
Old Aug 2, 2007 | 09:50 PM
timothy47129's Avatar
timothy47129
Its always better to break the clips than the door panel if you have to choose.Iv used a small prybar before.The ones about 2 inches wide and 6 inches long.Worked for me.
Tim
Old Aug 2, 2007 | 10:36 PM
psquare7575's Avatar
psquare7575
get one of these
Old Aug 3, 2007 | 09:34 PM
Pud12343's Avatar
Pud12343
i dont know what that is....lol
Old Aug 4, 2007 | 07:47 AM
psquare7575
It's a door panel clip remover
Old Aug 16, 2007 | 04:18 PM
Jonas1022's Avatar
Jonas1022
My 74 ahd metal sissor clips. And you can screw up your door panel very easily without the tool!
Old Aug 16, 2007 | 05:13 PM
blue68f100's Avatar
blue68f100
Use a piece of thin sheet metal and make a 90 deg break 1" from the end. Then slide it till you hit the clips then tilt side to side to pop them clean of the panel. Done it for years. The arm rest should have screws.
Old Aug 16, 2007 | 10:48 PM
Pud12343's Avatar
Pud12343
thanks guys, already did it lol, got it off fie without breaking anything.....had a good time gettin it back on tho. but i bought new clips and it went on in like 3 seconds
Old Aug 17, 2007 | 06:03 PM
johnritchie454's Avatar
johnritchie454
door panel
the door panel on the fords have 1 or maybe 2 phillips screws in top of the arm rest and there are plastic clips around the outer edge of the panel. the clips will brobably get messed up but they canbe found at any parts house cheap. the trick is to be careful because the door panels like to break in front of the window crank so be careful. just lift the edge of the panel and it should pop right off. hope this helps.
Old Aug 18, 2007 | 12:31 AM
BigGrizz76's Avatar
BigGrizz76
glad you got er done Pud! I know that those panels can be a BEAR!
pjtm8
Mar 8, 2011 10:19 PM
love2fixit
Sep 9, 2010 08:46 PM
chicagodragon
Apr 16, 2010 10:50 AM
dmcenery
2004 - 2008 F150
Oct 25, 2008 09:52 AM
ag-ford-4x4
May 4, 2006 06:55 PM
