Replacement Door Panels
Old Sep 8, 2010 | 07:09 PM
love2fixit's Avatar
love2fixit
Looking for replacement door panels for a 1985 Ford F250. Anyone recomend some good sites for GOOD replacements. And how about the other plastic panels like behind the seat and below the dash right and left of the floor board. Dont know what these panels are called but I need replacements as they are chalky and scrape off with fingernail.
Old Sep 8, 2010 | 07:29 PM
Fordzilla80's Avatar
Fordzilla80
Do NOT go with LMC or JC Whitney/Coverlay door panels if you're looking for factory accuracy. I find that the NPD door panels are closest to original. Or, you could try Dennis Carpenter. Expect higher prices with them.
Those panels are not reproduced, so you'll have to find some from a parts truck with better panels. If you can find some good panels that are the wrong color, you can always repaint them to match. SEM makes some great paint for interiors, but the key to a good paint job is adequate preparation.
My answers are in Red.
Old Sep 9, 2010 | 09:15 AM
JGreen236's Avatar
JGreen236
I believe NPD orders from Dennis Carpenter and Jeff's Bronco graveyard. I've bought a door, and the seals for the window, and it all had Bronco Graveyard on it.
Old Sep 9, 2010 | 03:21 PM
alhauger's Avatar
alhauger
The door panels on my 86 were chalky and had the same problem. I pulled them off, disassembled them, sanded them down and re-painted them. They look great now. As long as yours arent cracked ar busted, you could do the same and save yourself the hassle of looking for a good replacement. Especially for the panels they no longer reproduce.
Old Sep 9, 2010 | 07:18 PM
love2fixit's Avatar
love2fixit
My door panels are pretty thin(prob half as thin as should be) at the top by the window. I figured it would be better to replace them. So much scrapes off when you scratch them with fingernail.
Old Sep 9, 2010 | 08:46 PM
Fordzilla80
Alot of the companies use boxes from other companies for recycling purposes. Either way, I would trust all three of them.
The difference is in the speaker holes and the recess where the chrome trim ring goes on the higher trim levels. The cheaper panels just have a grid of holes drilled into them. The ones NPD show in their catalog have a speaker grille close to the factory one. I just looked in my JBG catalog, and it shows two of the door panels being like NPD panels, but the base door panel had the grid of holes.
steveamann
Jun 10, 2013 02:11 PM
TNT
Oct 20, 2012 09:18 PM
mikeg216
Nov 22, 2011 07:56 AM
zombey
1997 - 2003 F150
Nov 5, 2010 06:48 PM
dmcenery
2004 - 2008 F150
Oct 25, 2008 09:52 AM
