help,Glow plugs stop working
Judging on where you live, you don't need glow plugs to get the engine started, even if you let the truck sit for three days. Especially if it's only sat for two hours and it's hard to start again. Your starting problem is something else, but what it is I am not sure.
The list of possibilities include, worn out valve cover wiring to the injectors or the plug has come loose inside.
With your fuel pickup having a hole in it it could be letting a TON of air into the fuel stream and the fuel pump needs some time to clear out all the air bubbles that are in the fuel rails. This is a VERY common problem and is easily fixed with the proper mods and the results can be dramatic.
A cracked engine oil pickup tube that is airating the lube oil before it gets to the HPOP and it needs some time to compress the air bubbles in the HPOP rail.
A crack in the soldering for the IDM (Injector Driver Module) that is closing enough to run good after you start it. (This one seems very unlikely to me.)
Any other ideas, guys?
<TABLE cellSpacing=1 cellPadding=3 width=436 border=1><TBODY><TR><TD vAlign=bottom width="10%">
</TD><TD vAlign=bottom width="24%">
</TD><TD vAlign=bottom width="65%">
</TD></TR><TR><TD vAlign=center width="10%">1
</TD><TD vAlign=center width="24%">9278
</TD><TD vAlign=center width="65%">Oil Pressure Sensor
</TD></TR><TR><TD vAlign=center width="10%">2
</TD><TD vAlign=center width="24%">6600
</TD><TD vAlign=center width="65%">High-Pressure Oil Pump
</TD></TR><TR><TD vAlign=center width="10%">3
</TD><TD vAlign=center width="24%">6049
</TD><TD vAlign=center width="65%">Cylinder Head
</TD></TR><TR><TD vAlign=center width="10%">4
</TD><TD vAlign=center width="24%">9A332
</TD><TD vAlign=center width="65%">High-Pressure Oil Feed Hoses
</TD></TR><TR><TD vAlign=center width="10%">5
</TD><TD vAlign=center width="24%">—
</TD><TD vAlign=center width="65%">High-Pressure Oil Rail
(Part of 6049)
</TD></TR><TR><TD vAlign=center width="10%">6
</TD><TD vAlign=center width="65%">Injector Oil Feed Galleries
(Part of 6049)
</TD></TR><TR><TD vAlign=center width="10%">7
</TD><TD vAlign=center width="24%">9F593
</TD><TD vAlign=center width="65%">Fuel Injectors (8 Req'd)
</TD></TR><TR><TD vAlign=center width="10%">8
</TD><TD vAlign=center width="24%">9F838
</TD></TR><TR><TD vAlign=center width="10%">9
</TD><TD vAlign=center width="24%">7A139
</TD><TD vAlign=center width="65%">Oil Pressure Regulator
</TD></TR><TR><TD vAlign=center width="10%">10
</TD><TD vAlign=center width="24%">6019
</TD><TD vAlign=center width="65%">Engine Front Cover
</TD></TR><TR><TD vAlign=center width="10%">11
</TD><TD vAlign=center width="24%">6658
</TD><TD vAlign=center width="65%">High-Pressure Oil Pump Reservoir
</TD></TR></TBODY></TABLE>
During initial start or cold start, the high-pressure oil pump (6600) receives unfiltered oil from the left side valve lifter oil gallery through the anti-drain back check ball valve. Once the engine starts or during warm engine starts, the check ball closes and the high-pressure oil pump receives filtered oil from the high-pressure oil pump reservoir. The high-pressure oil pump pumps the oil under extremely high pressures 4,115-20,577 kPa (600-3,000 psi) through the left and right side high-pressure supply hoses to the high-pressure oil rails (integral to the cylinder heads). Once in the oil rail, the oil is fed to the fuel injector bores through four oil feed galleries drilled and machined in the cylinder head. The high-pressure oil then actuates the fuel injectors.
On top of the HPOP Oil Reservoir is an allen bolt that you can remove to see how far the oil is from the top. Should be less than an inch from the top I believe.
Dave
This is a good little write up that briefly explains how the injectors work.
http://www.intellidog.com/dieselmann/injector.htm
Yes you can clean the injectors, but I recommend that you buy new o-rings for the ones that you pull. Make sure that you clear out the cylinders before you reinstall them or you will hydro-lock the engine. The easiest way to do that is to remove the glow plug and crank the engine by hand first and then using the starter after that. Don't just crank it over with the starter and a cylinder full of oil, the oil will shoot out of the glow plug hole as hard as a pressure washer! You stand a good chance of damaging the engine because of the hydraulic shock and at the very least having a bunch of oil to clean up.
As far as the Seattle rain, it doesn't rain 24/7 up here, so you must have missed the good days.
