Sponsored by: Real Truck
08 King Ranch Wheels
Old Aug 3, 2007 | 08:28 PM
A. Michael Foxtrot's Avatar
A. Michael Foxtrot
Thanks for the correction on the offset of the new '08 wheels. Didn't know there was a difference from the previous couple years.
Old Aug 4, 2007 | 12:16 AM
mikedeason's Avatar
mikedeason
Thumbs up
Wow,
Great info.
The tires are 13.1 and rated for 8.5-11 so I will give the KR wheels a shot and keep an eye on feathering.
So why do they rate a 13.1 tire as a 12.5 instead of a 13????
Old Aug 4, 2007 | 12:59 AM
PowerStrokeHD's Avatar
PowerStrokeHD
Originally Posted by mikedeason
Wow,
Great info.
Its just the way it works. It is not 13.50 and there is no 13.00, so it fits in the catagory of 12.50. Just like my 12.50's are actually 12.90.
I am not sure if you know or not... Using factory 18" or 20" and 37X12.50R**, there is a chance of a slight rub on the frame at full steering lock. Not a big deal though.
Make sure you drop Cooper a e-mail for the load/inflation table for your tire. They have been very helpful in my contacts with them.
ConsumerQualitySystems@coopertire.com
Do you know what the load range of the STT you are looking at is?
Old Aug 4, 2007 | 08:04 PM
mikedeason's Avatar
mikedeason
Thumbs up
Load range D.
The tire is actually a 37X12.5X17.
If I get the 18" KR wheels I will have them machined to fit the tire.
When I ran the 13.5 Toyo tire on a 7.5 wheel, I had real problems w/unneven tread wear but I just used the recommended psi.
Old Aug 4, 2007 | 09:21 PM
PowerStrokeHD
Load range D.
Sounds crazy, but would it not be easier just to get 37X12.50R18 tires? Not sure if you are looking for A/T or M/T, but they are out there. Some of them are even load range E.
I know you can machine 22.5" wheels down to fit 22's, but I have never heard of taking a inch off a factory wheel. I do not see it working, but then again I have never looked into trying it!
As for a 13.5 on a 7.5", I would expect poor tire wear even if you tweaked the air pressures. I would not even put 13.5 on a 8" let alone a 7.5".
Old Aug 4, 2007 | 10:29 PM
mikedeason's Avatar
mikedeason
Arrow
Well, I can get the KR wheels for $200 (brand new) and I already got the 37X12.5X17 STT's so I will give machining a shot.
I don't think I got to go down a full 1", probably just try for 17.5"
kenwhelan
2004 - 2008 F150
May 2, 2009 09:06 PM
ffdemoss
6.4L Power Stroke Diesel
Feb 21, 2007 05:14 AM
Shadowe
2004 - 2008 F150
Jul 20, 2005 06:33 PM
dusty1
2004 - 2008 F150
Jun 14, 2004 08:28 PM
