Sponsored by: Auxito
Alarm
Old Aug 3, 2002 | 07:04 PM
whomrig's Avatar
whomrig
Alarm
Hey out there.....I recently bought a pre-owned 2000 F-150 XLT and it seems when I park it, get out, lock the doors with the inside lock button, then unlock it with the key in the door, the alarm goes off, or the engine won't crank over. It seems I always need to unlock the alarm with the key fob remote, then all is normal. Can this be programmed or do I have a problem with the alarm system? I was told I may have a "Viper" system but it looks factory installed to me.
Wayne
1960 F-350
2000 F-150
Old Aug 9, 2002 | 08:15 PM
MrBSS's Avatar
MrBSS
Alarm
There should be a sensor that disarms the alarm when using the key. If properly installed, this would be on both the driver and passenger doors. If this happens when you use the key in either door, then they were probably never installed (installation is considerably easier without them). Otherwise, one may have gone bad. It seems unlikely that both would have failed.
MrBSS
Old Aug 9, 2002 | 08:44 PM
triumphjim's Avatar
triumphjim
Alarm
F150canative
N. California Chapter
Jul 28, 2009 03:54 PM
PEG
1997 - 2003 F150
18
May 19, 2009 04:40 PM
lghtningstruk
Jul 13, 2002 07:48 PM
