tndiesel
Old Aug 1, 2007 | 06:43 PM
Suber's Avatar
Suber
Smile tndiesel
Just making sure you did not decide to SELL your truck out of frustration over that coolant temp gauge! I have not seen him on in a while. Perhaps vacation!
Old Aug 1, 2007 | 07:04 PM
Neal 97 250's Avatar
Neal 97 250
I spoke with him today. I am oredring him the overflow tank that has a hole in it.
Old Aug 1, 2007 | 08:01 PM
tndiesel's Avatar
tndiesel
Sorry, I'm still here. I've been working cattle the last few days with a family friend. I still have my big quarter size hole in the firewall and am running water in the rad for about 1 more week when I put the 50/50 mix I'll try the gauge again. My tranny fluid only has about 12K miles on it and looks realy fresh/good. When I put the tranny gauge can I try to catch what come out while putting the sensor in and refill it with what I catch?
Old Aug 1, 2007 | 08:07 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
It should leak only a little, so you dont have to add anything, unless you loose a lot of fluid. Install the sender quickly and thats it. OK?
Old Aug 1, 2007 | 08:11 PM
tndiesel's Avatar
tndiesel
Hope you are right, sounds good.
Old Aug 1, 2007 | 08:13 PM
MLCinNCTX's Avatar
MLCinNCTX
Put a pan under the tranny, but I don't remember much coming out when the plug is removed. Someone that has done the tranny gauge recently tune me up if I am not remembering correctly.
I am not a big fan of catch and re-use unless it is a very unusal situation. Oil is is to cheap to risk crap falling off the bottom of the truck and into the pcaught oil. Each their own.
Old Aug 1, 2007 | 08:16 PM
Suber's Avatar
Suber
It is a very small amount of fluid. If you do it with the tranny cool, it almost oozes out of the port. Glad you are still around.
Old Aug 1, 2007 | 08:46 PM
Neal 97 250
I agree do it cold and it will be thick so not much loss. And just add new and don't reuse.
Old Aug 1, 2007 | 08:48 PM
tndiesel's Avatar
tndiesel
Thanks, your's and other's knowledge here is my saving grace. Also, when I do the tranny gauge I'm going to put a new tranny cooler in. Can you refresh my memory on which one to get?
Thanks!
Old Aug 1, 2007 | 08:50 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Ill recomend TRU-COOL MAX.
Old Aug 1, 2007 | 08:52 PM
Suber's Avatar
Suber
YEP! Easy install and many here have done it on their trucks, so you will have NO problem!
Old Aug 1, 2007 | 08:55 PM
c00nhunterjoe's Avatar
c00nhunterjoe
has anybody tried the one out of a 6.0? they are HUGE! and a direct bolt in for 99 ups, i am debating trying it in mine, might mate good to the 6.0 intercooler.
Aerostar
Aug 21, 2024 11:23 PM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Mar 11, 2001 10:13 PM
