Brake problem
Old Jul 31, 2007 | 04:51 PM
vpost's Avatar
vpost
Brake problem
I have a 76 F250 hiboy with a 360 CID, the problem is when I get the RPM's above 1000 or so the brake pedal fall on it's own and will not come back up on it's own till I shut the truck down. I've looked for vacuum leaks and unable to find any. The vac booster and master cylinder are relatively new. Any thoughts?
BTW this is my first post here and this is an awsome site!
thanks
Vince
Old Aug 18, 2007 | 02:02 PM
vpost's Avatar
vpost
OK, no thoughts? how about any ideas?
Old Aug 18, 2007 | 02:17 PM
blue68f100's Avatar
blue68f100
Check the booster check valve. It's the plastic part that plugs into the booster. You should still have brakes even if it fails if the rods are adjusted properly. It's a fail safe, will require more petal pressure.
Also. Since you have change the MS and Booster, did you adjust the rods to proper lengths? The booster to MS should be little to no play. Then the Petal to Booster is where you adjust your petal play.
Old Aug 19, 2007 | 01:11 AM
Mil1ion's Avatar
Mil1ion
Old Aug 20, 2007 | 08:47 AM
vpost's Avatar
vpost
Ok, thanks guys, I'll try both of those and post what I find.
Vince
Old Aug 20, 2007 | 08:11 PM
rusty7983's Avatar
rusty7983
try puliing the vaccuum hose and see if it makes a difference. just be careful if you drive it, try it at a stop if possible.
Old Oct 21, 2007 | 11:16 PM
vpost's Avatar
vpost
Ok guys,
Thanks for the input, I found that the booster was leaking in the back where the rod goes through, never thought to look there. lesson learned.
Thanks
Vince
Merkatroyd
Jun 4, 2010 08:39 AM
78workhorse
13
Sep 11, 2007 07:54 PM
clarketec
Jan 4, 2007 01:12 PM
94FSuperDuty
Dec 3, 2005 11:15 PM
vancouverpower
Jul 14, 2005 10:10 AM
