4v intake
Old Jun 28, 2000 | 01:24 PM
jkt's Avatar
jkt
4v intake
I had found an old 4v intake just laying around and it seems to bb in pretty good condition but i dont know what it goes to, hear are the numbers on the intake:
S C8AE Firing order: 15426378
9425-f
all help would be greatly apperated
Old Jun 28, 2000 | 01:47 PM
Nathan's Avatar
Nathan
4v intake
The small blocks and 385 series big blocks have the firing order you stated. M blocks and 351W have 13726548 firing order.
Nathan
Old Jun 28, 2000 | 02:17 PM
jkt's Avatar
jkt
4v intake
Old Dec 3, 2004 | 06:47 PM
LedheadELH's Avatar
LedheadELH
it would either be an FE or a 385.......if it is a small block, you would DEFINETLEY be able to tell the difference between that and a BB.......BB's are like twice as big...well those 2 BB's are neways!
there is also a big difference between an FE intake and a 385 Intake.....the FE's intake is part of the vavle cover gasket, and the FE intake only has like...10 intake bolts
the 385 has 16
BTW 385 series= 429, and 460
FE series=352,360,390,406,410,427,428
Old Dec 4, 2004 | 08:55 PM
Icicle's Avatar
Icicle
I believe in deciphering the part number its an intake off of a 68+ car, not a truck, and if its 4v its PROBABLY not a small block intake....most likely a 385 series intake, if its just cluttering uo your garage I can take it off your hands for ya J/K
Old Dec 5, 2004 | 09:27 AM
WillyB's Avatar
WillyB
Just tried to look that number up - then discovered on mine it was C3AE-9425. Still didn't find it, but know my manifold came off a 1965 Merc 390 (FE).
Does it have an oil filler tube in the front?
Old Dec 6, 2004 | 09:13 AM
Mike G's Avatar
Mike G
9425-f
That would be a "S" code 4v for an FE (352-428), usually found mounted to late 60's FE powered Mustangs, Cougars and the like. I'm guessing that you found it weighs about 60lbs... There should be what I call ears at the ends of the manifold, these will extend about 1/3 way down the block surface and mount up with the heads. There will also be three bolt holes (two on ends and one in the middle) for the valve covers.
--Mike
Old Dec 6, 2004 | 02:53 PM
fordeverpower's Avatar
fordeverpower
--Mike
I totally agree thats its FE series intake and nothing else. I have actually weighed my 4v intake and with a dab of coolant it weighed 80 lbs. The FE intake weigh 75-80lbs.
20015.4f350
Oct 15, 2014 08:34 PM
650
May 20, 2012 03:57 PM
chops1987
Mar 14, 2007 08:10 PM
Rat wagon
Mar 11, 2003 03:30 PM
Zs514rd
Aug 23, 2001 09:26 AM
