Max Tire Size?
The original poster was asking for the largest diameter tire that would fit on a stock suspension.
I should know, I was the original poster. Any info on that point?
like i said, i have 305/45/22's. its a 33" tire. it's 12" wide. again, depending on your wheel offset and backspacing, i wouldn't go any wider or taller either. i have all stock suspension except for the v springs. and i get absolutely no rubbing. although its super close when the wheel is turned to full lock. hope that helps...
oh, and then at least you use your truck for what it was built for then....
The "new" tire sizes are based on a metric/percentage/inch system. Yeah. I know.
First, if the tire has a "P" in it, it a Passenger-vehicle rated tire. If it has an "LT", it's a Light Truck-vehicle rated tire. I can't give you a good technical explanation of the difference between the two, but there is a difference. Good question for a tire man.
Now, about the numbers (I'll use your sizes for example):
305/70-16 or 285/75-16
305 is millimeters, and determines the HEIGHT of the tire. (That is, the "Section Height"..from the tread surface to the bead (inside edge/diameter).
70 is percentage, and determines the WIDTH of the tire.
16 is inches, and is exactly the INSIDE DIAMETER of the tire, thus the diameter of the rim that fits.
Not trying to stir things but....................this is not exactly correct!
The 305 is millimeters but it dtermines the width NOT height of the tire. The tire tread is 305 mm's wide.
The 70 is a percentage but it is a percentage of the tread width and is used to determine the sidewall heigth. 70% of 305mm is 213.5mm. The sidewall of the tire is 213.5mm in heigth.
The 16 is indeed the rim diameter.
Try this if I did'nt expalin it very well............
http://www.tirerack.com/tires/tirete....jsp?techid=46
Great place to compare tire sizes at the bottom of this page.....
http://www.miata.net/garage/tirecalc.html
thanks
Firestone's? -- I wouldn't use their best tire for a watering trough in my yard! I wouldn't MAKE a good dog drink outa something like that even if he was thirsty to death!
Is there really a difference since Bridgestone Firestone North America manafacture Revos that you would run ragged and also the Firestones that have not even earned a place in your yard.
Not to be a jerk but it seems you would find both equally acceptable or unacceptable due to make actually being the same.
