1978 - 1996 Big Bronco
Vibration while turning
Old Jul 30, 2007 | 11:52 AM
johnarahill's Avatar
johnarahill
When I turn my 88 Bronco either direction, the truck vibrates. It feels like the tires are rubbing, but they are not, as I have checked for this several times. The vibration is only when I've got the wheel b/w 1/2 and 3/4 of a turn in either direction, once I steer more into the turn, it stops. I've stopped the truck in mid-turn, gotten out and looked all around and haven't been able to find anything that looks out of place or anything like that.
Old Jul 31, 2007 | 01:07 PM
hunter1897's Avatar
hunter1897
Do you have a limited slip differential in front and are you in 4WD at the time? Otherwise if not, perhaps as your tires, as they are turning and the camber is changing as you turn, you are getting the outside of your tires to contact the road surface at a natural frequency during the turn until you turn further and the frequency changes.
Old Jul 31, 2007 | 02:19 PM
johnarahill
I'm not in 4wd when it happens, although I haven't looked at the axles to see if they are turning anyway, which might cause a problem.
reylings
Oct 23, 2012 08:32 PM
Jeff396
Jul 22, 2012 09:20 PM
phishfood4311
Jan 3, 2012 05:56 PM
mowreyp
2004 - 2008 F150
Apr 17, 2005 04:02 AM
