Missing teeth on the flywheel
Old Jul 30, 2007 | 11:19 AM
enprse's Avatar
enprse
Unhappy Missing teeth on the flywheel
I have '86 F250 6.9 diesel w/auto transmission that the flywheel needs to be replaced because teeth are missing. I pulled the starter and the gear is engaging approx. 1/3 of the starter gear and about 2/3 to 4/3 of the flywheel.
Should the gear be engaging more of the flywheel? If so, is the starter shimmed on this year & model?
What is the torque spec for the flywheel bolts?
Old Jul 30, 2007 | 04:33 PM
PLC7.3's Avatar
PLC7.3
Is it the OEM starter or the Mitsubishi.... Mitsu has internal adjustment of the Bendix throw arm.
Flywheel bolts are 47 ftlbs.....use correct sealant on the bolt threads (they go into the oil pan area).
Old Jul 30, 2007 | 08:15 PM
enprse's Avatar
enprse
Thank you for the reply.
How can I tell if the starter is an OEM or the Mitsubishi?
rollpan
Aug 4, 2009 01:30 PM
randomhero1172
15
Mar 4, 2009 03:51 PM
blueovalinvestments
Oct 27, 2004 07:58 AM
rattle_ping
1983 - 2012 Ranger & B-Series
Dec 29, 2003 09:52 PM
Katt
Nov 11, 2001 08:48 PM
