Sponsored by: Auxito
Bolt pattern?
Old Jul 29, 2007 | 11:48 PM
v8xploder's Avatar
v8xploder
Bolt pattern?
What is the bolt pattern on the 5 lug F-150 wheels? I believe they are 16's or 17's five spoke design. I know the newer ones have the same wheel but they are six lug. Thanks
Old Jul 29, 2007 | 11:50 PM
wgotthardt's Avatar
wgotthardt
5X135mm (97-03, 04 Heritage)
Newer (04-current) are 6X135mm
Old Jul 31, 2007 | 10:17 PM
v8xploder's Avatar
v8xploder
awesome thanks! I have an idea on when I buy a set of axels front and rear for my 69 bronco to run newer F150 wheels on it. Since they have to be custom made any way I would like to have the bolt pattern changed to the newer style Im trying to keep the body looking stock and the whole truck to look like it came from the factory, except for the 5.5 inch lift and 35's
Old Aug 1, 2007 | 12:08 AM
LxMan1's Avatar
LxMan1
The newer style wheels are hub ecentric, which means they center on the hub, not the lugs so make sure your custom axles have the same hub diameter as the newer 97-up trucks.
Old Aug 1, 2007 | 12:12 AM
galaxie641's Avatar
galaxie641
Also note the '97 and '98's were 12mm studs, whereas they went to 14mm studs some time in '99.
Old Aug 1, 2007 | 10:07 PM
v8xploder's Avatar
v8xploder
Good info, i didnt even think of that, ill have to price them with all of that, they might be a lot more than I thought...
SuperDuty93
May 5, 2014 12:22 AM
jibronee
24
Jun 29, 2012 07:06 PM
limited4life
Jan 26, 2011 11:08 AM
Jeff3298
Sep 7, 2008 10:19 PM
mdclass2001
Aug 24, 2004 12:05 AM
