Trans pan bolt torque
Old Jul 29, 2007 | 09:08 PM
bronzo510's Avatar
bronzo510
Anyone know the torque for the transmission fluid pan bolts on a C6? All I have is the diesel engine manual - need to do something about that...
Old Jul 29, 2007 | 09:23 PM
RickDill1's Avatar
RickDill1
I don't think trans pans require a tork wrench. just a even snug on all bolts cross tightened. Silicon is suggested too.
Old Jul 29, 2007 | 09:31 PM
Franklin2's Avatar
Franklin2
I have seen it done, but I try to avoid silicone on tranny gaskets. Too easy to clog things up.
Before you put the pan on, you should hold it against the edge of a bench, and take a hammer and flatten the metal around the bolt holes. Then when installing the pan, tighten the bolts with a ratchet and socket, with your hand over the head of the ratchet. Go around a couple of times like this, and that should be it. Holding you hand over the head of the ratchet will limit the torque you can apply. If you tighten it too much, you just end up bending the pan around the bolt holes again.
After a week of driving you can get under there and check the bolts again, incase the gasket shrinks.
Old Jul 29, 2007 | 09:42 PM
bronzo510's Avatar
bronzo510
That was the general method I used. Sugged it up pretty good but it looks like it's starting to seep a bit. At this point I worry about overtightening and splitting the gasket - an experience i've unfortunatley been through before.
Old Jul 31, 2007 | 12:03 AM
hoxiii's Avatar
hoxiii
10-12 ft*lbs if you wanna be particular.
Justin
sgrol
6.7L Power Stroke Diesel
15
Apr 14, 2017 03:40 PM
sgrol
Apr 14, 2017 12:48 PM
T diesel
Apr 7, 2017 11:03 PM
neilc88
Modular V10 (6.8l)
May 31, 2013 09:13 AM
bridge
Nov 11, 2012 07:49 AM
