How to pull codes
Old Jul 28, 2007 | 05:15 PM
351slug's Avatar
351slug
How to pull codes
I have a 93 F-150 4x4 351W SD E40d,3.55 gears. The check engine light is coming on and off and the trans is acting up. Will trans problems show up on scanner? I am old school and have never pulled codes before. Has been running great then all of a sudden, starts cutting out during heavy throttle and shifting sluggish, speedometer is skipping.
Old Jul 28, 2007 | 05:45 PM
Dean88's Avatar
Dean88
Heres a link of how to pull codes: http://www.fordfuelinjection.com/?p=13
Its extremly easy to do, and doesn't require a scanner.
Old Jul 28, 2007 | 06:36 PM
jroehl's Avatar
jroehl
Sounds like your VSS is dirty, loose or broken. Probably just dirty. It's the only electrical item that goes into your rear differential.
Jason
Old Jul 28, 2007 | 06:43 PM
quicklook2's Avatar
quicklook2
best thing i ever bought was the equis electric obd I reader.
Old Jul 29, 2007 | 01:52 PM
351slug's Avatar
351slug
Bought a scanner today and it doesnt look good for the E40d. Code 62 and 628. Looks like a 12,28,122. I will try again to make sure. Where is the TP sensor and what does it do ?
Old Jul 29, 2007 | 01:58 PM
ncguy23's Avatar
ncguy23
Double check those codes, I made this mistake myself: you only get either 2 OR 3 digit codes, not both. The code reader shows each code twice, spacer single flash, then the continuous memory codes
Jon
Old Jul 29, 2007 | 02:00 PM
ncguy23's Avatar
ncguy23
TP sensor is located underneath the throttle body intake, pretty much tells the computor how open or closed the throttle is.
http://www.fordfuelinjection.com/?p=30
Old Jul 29, 2007 | 03:07 PM
351slug's Avatar
351slug
OK did again its a 3 digit.121,122,128,128,628. Not much I can do about 628. Looks like I will need to replace TP sensor and look at vacum lines going to MAP sensor. Thanks for the help.
