I have a 93 F-150 4x4 351W SD E40d,3.55 gears. The check engine light is coming on and off and the trans is acting up. Will trans problems show up on scanner? I am old school and have never pulled codes before. Has been running great then all of a sudden, starts cutting out during heavy throttle and shifting sluggish, speedometer is skipping.
Bought a scanner today and it doesnt look good for the E40d. Code 62 and 628. Looks like a 12,28,122. I will try again to make sure. Where is the TP sensor and what does it do ?
Double check those codes, I made this mistake myself: you only get either 2 OR 3 digit codes, not both. The code reader shows each code twice, spacer single flash, then the continuous memory codes
OK did again its a 3 digit.121,122,128,128,628. Not much I can do about 628. Looks like I will need to replace TP sensor and look at vacum lines going to MAP sensor. Thanks for the help.
