Bolt's
Old Jul 27, 2007 | 03:56 PM
mkrog's Avatar
mkrog
Bolt's
Where can I get the bolts that attache's the door to the hinge.This is the bolt that has a unthreaded tip that is smaller.The size is 5/16 fine thread.
Oh sorry this is for a 1957 F 100.
Looked every where and can't find any.
Old Jul 27, 2007 | 04:47 PM
LEckart's Avatar
LEckart
Unless your doing a 100 point restoration any 5/16-24 hex head bolt should work.
Old Jul 27, 2007 | 04:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1957/60 F100/1100:
20387-S8 .. Bolt-Hex Head-Door Hinge - 5/16" -24 X 1"
20327-S8 .. Bolt-Hex Head-Door Hinge - 5/16" -24 X 5/8"
34806-S7 .. Lock Washer-Door Hinge - Spring Type - 5/16"
You might try a (long established) Ford dealer, as they generally never throw hardware away. Most of the time, hardware isn't inventoried, and may lay unmolested in a drawer for years.
Junkyard caveat: 1961 and later trucks use 3/8" door hinge bolts.
Old Jul 27, 2007 | 05:05 PM
AXracer's Avatar
AXracer
Mid Fifty carries a lot of replacement bolt sets. Those bolts were commonly used by Ford for much of the body assembly. You may also find them from McMaster-Carr.
Old Jul 27, 2007 | 06:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The unthreaded part is to guide the bolt in on the assembly line, when using a power driver. Some of them also have thread-cutting starter threads. I'd go with quality hardware store bolts (if there is such a thing any more).
Old Jul 27, 2007 | 07:43 PM
60RatRod's Avatar
60RatRod
I have always used Gardner Westcott fastners at my shop. Their quality is second to none. http://www.gardner-westcott.com/
Old Jul 27, 2007 | 08:00 PM
mechmagcn's Avatar
mechmagcn
Another source, try a local Mack truck dealer. Mack used the 5/16-24 thread bolts with the pilot tip on many things, especially on the R-Model trucks.
Old Jul 28, 2007 | 02:49 AM
mkrog's Avatar
mkrog
thanks
thanks everybody for the replys.I would like to get the type with the pilot tip because they thread into cage nuts and are a lot easer to get started.
Old Jul 28, 2007 | 11:03 PM
51PanelMan's Avatar
51PanelMan
Another possibility is www.fastenal.com
Old Jul 29, 2007 | 09:33 AM
bigwin56f100's Avatar
bigwin56f100
How many do you need? I'm sure I have some
Kevin Bigwin
Old Jul 29, 2007 | 10:28 AM
mkrog's Avatar
mkrog
I found some,a place C&G Early Ford Parts has them in there catalogand I ordered some,the all so have the cage nuts.
Thanks All
powerram50
Feb 7, 2009 03:53 PM
Warren Mitchell
Jun 14, 2008 07:03 PM
1991redneckf150
Feb 12, 2007 01:59 PM
fellro86
17
Sep 13, 2005 11:58 PM
f-250.4x4.390
Garage & Workshop
13
Jun 23, 2004 02:13 PM
