vibrations from drivetrain
Old Jul 27, 2007 | 01:26 PM
kilson's Avatar
kilson
Unhappy vibrations from drivetrain
i have a 1999 f250 p.s. 4x4 c.c. it has 160,000 miles on it. i am experiencing some vibration from somewhere on the drivetrain. i changed the carrier bearing thinking that this was the problem, but not successful. the vibrations come at different speeds & go away when i come to a stop (or just about stopped). it feels like when you have a flat (or multiple flats). it doesn't drive or shift any different than normal. please help!
Old Jul 27, 2007 | 02:51 PM
mikekin1's Avatar
mikekin1
sounds like u-joints are shot. do you get a clunk when you put it in gear?
had the same prob on my 87 changed ujoints no more vibration about 15.00ea at a parts house for heavy duty
hope this helps
welcome to FTE
Old Jul 27, 2007 | 03:14 PM
kilson's Avatar
kilson
not really, but every once in a while it will "clunk". would this happen sparatically? there is no set speed or driving condition when it happens. thanks
Old Jul 27, 2007 | 03:23 PM
mikekin1's Avatar
mikekin1
it could my 84 only did it certain times never when putting in gear, letting off the clutch the 87 did it when going into reverse only doesnt hurt to replace them anyway i would do all 4 primary joints dont forget to mark the drive shafts so it goes back the same way it came out (balancing issue)
Old Jul 27, 2007 | 03:30 PM
kilson's Avatar
kilson
thanks, will give it a shot.
Rondub
New Member Introductions
Feb 12, 2006 04:12 PM
