95 e-250 hard shift, bad vibe between shift
my van shifts hard in to second and but does not seem so if its cold, like start and go. But if i drive through the gears slow or normal it some times vibrates real bad till i let of the gas or just punch it. dosent seem to be the rear end or the u joints , but ther is a slight vibration @ 55mp+ .There does seem to be some play and wear in the trans spline/shaft , maybe no blue plastic sleeve on trans-shaft to drive shaft. Ive only had this van for a week. 173K on odometer i also see someone has changed the rear u joint.is there some thing in or at the end of the trans tail housing that would or could cause this ???????????????? thanks
just wonder whatelse to look for past the drive train
If you get a minute check out the link here, it will help you to navigate around and understand this site.
To find out where to ask the question, click on this link
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
