I beleive the connector is inside the door. You have to take the door panel off to get at it. There is a link to instructions on removing the door panel in the tech folder I beleive (first thread in this forum).
thanks for the replys, i removed the switch assembly on the armrest, but the wire looks nothing like the one coming out of the mirror. so i guess i have to remove the door panel to see the connector. being that i only have power mirrors, woulld i have to get the exact plug , or is an adaptor available
yeah remove the 2 screws...one behine the reflector and on up by the door arm rest...and also you have to remove the switch assembly like you did and than lift the door panel straight up...viola!!! there is the plug...goodluck...
took off door panel, and it is a round plug that goes into a square fitting.
countermaker, by only power, i meant that they were non heated, and don't have signals on them. thanks for the advice on panel removal.
had to remove speaker to see plug.
didn't think the price was too bad $138.00 for the pair delivered
