M5OD Slave Cylinder
Old Jul 26, 2007 | 01:26 AM
red bud's Avatar
red bud
M5OD Slave Cylinder
I'm putting a '89 M5OD in my '94 f150. The two different years uses different slave cylinders. Question is which one do I use? Thanks
Old Jul 26, 2007 | 11:19 AM
loudfords's Avatar
loudfords
Important thing is to keep the master & slave as a matched set. If you keep your 94 master cylinder, use the 94 slave cylinder.
Old Jul 26, 2007 | 12:20 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't know that Ford ever changed the bore of the clutch master cylinders, so keeping the year together between the master and slave doesn't seem that important. Just verify that the bores are indeed the same, and it should be ok. I would think that it's more important to have one that will bolt in to the appropriate space on the firewall, since that bolt configuration did change over the years.
ringokman
Jun 11, 2010 10:02 AM
red bud
Aug 30, 2007 08:45 AM
mud2084
1983 - 2012 Ranger & B-Series
Jan 30, 2004 06:37 PM
NathanV
Sep 9, 2003 08:30 PM
