5" MKO install help
Old Jul 26, 2007 | 12:30 AM
01PS's Avatar
01PS
5" MKO install help
Maybe I'm just a dummy? I'm having one heck of a time installing my 5" MKO kit on my 01 F250 EC SB. I got the DP on just fine, but can't sem to get anything else to line up or look like it will clear. Maybe my hangers are bad? They won't even support the weight of the pipe without sagging and throwing the whole thing off. I'd like to get it on tonight, but don't want to call Mark this late. Any help/pics appreciated!!!!!
Old Jul 26, 2007 | 12:46 AM
pullinair's Avatar
pullinair
Check out my gallery, Ive got pics of the sysyem hanging. As far as hanging it, do not tighten anything until the whole system is pieced together. Then go through and start tightening each piece one at a time.
Old Jul 26, 2007 | 12:58 AM
01PS's Avatar
01PS
Okay, maybe my hangers are the culprit. In your gallery the pic "Stove Pipe!", ur hangers a WAAAAAY more supportive than mine. Mine are all mushy and such. I have the 5" MD no tip on a EC SB btw. If anyone else has this same setup, I'd be interested to se s'more pics! The instructions leave a bit to be desired (no illustrations as to which part is which) but it seems like it'll look pretty awesome when I'm done!!!
Old Jul 26, 2007 | 01:43 AM
Badluck's Avatar
Badluck
yea I have a 4'' kit but had no prob with the hangers or anything not lining up, it went together really nice
Old Jul 26, 2007 | 02:26 AM
pullinair's Avatar
pullinair
My hangers have 170,000 miles on them. I doubt it is youre hangers. You will see how the system strengthens/straightens/tightens up as you start tightening the exhaust clamps. JMHO
Old Jul 26, 2007 | 02:53 AM
01PS's Avatar
01PS
Here's the part that's killin' me. I can't get the tail pipe on right without it resting on the fender, or on the rear shock. Approx where should the rear hanger be on the tail pipe piece? Also, when I think the tail pipe and the piece that goes over the axle look good, I find that they are WAAAAAY off from lining up for the extension pipe to go in. The hangers don't actually keep the thing up off the bolts that the flat spot is there for either. Really thinking the hangers are shot. Hoping I'm not just too stupid to do this. Pic of worst looking hanger attached (I think).
Old Jul 26, 2007 | 02:58 AM
01PS's Avatar
01PS
I thought I posted this q earlier but I guess not. Can I run this thing with just the DP and next section on? I need to take it to work and as of now I only have time for 4.5 hrs of sleep.
Old Jul 26, 2007 | 03:23 AM
ron's power stroke's Avatar
ron's power stroke
yes you can run it that way for a short bit..looks to me like you didnt get the tail pipe put together quite right for it too be sitting that way..it does get confusing
Old Jul 26, 2007 | 03:42 AM
pullinair's Avatar
pullinair
Keeping it off the shock is gonna be hard. Tighten the last bend that the tip would attach to. Then make your adjustments moving forward on the exhaust, maintaining that last bend from touching the shock.
