Sponsored by: Auxito
ABS comes on going slow?
Old Jul 24, 2007 | 11:27 AM
01 silver sport's Avatar
01 silver sport
My 2001 4x4 f150 ABS comes on under a few MPH 90% of the time, I can feel it in the brake pedal. Some times it comes on when I' going a few MPH without my foot on the pedal, I can feel a buzz in the floor. My mechanic has cleaned all the sensors & checked everything.
Do I have 4WABS?
I saw a post that its a Teves 4 ABS, Is this ture for a 01 4x4?
Can Autozone do a free scan to locate the fault?
I see the front ABS sensors are about $122 each for a 4x4, $ 19 for rear.
Thanks,
Jerry
<!-- / message -->
Old Jul 24, 2007 | 12:18 PM
66f25red's Avatar
66f25red
The sensor wire at the wheel can have internal open condition, causing the system to think that wheel is locked and ABS trys to make things right. You can test the sensors with digital ohm meter, while the meter is attatch to the sensor harness ( unplug from the frame) wiggle the wire and see if you find an intermittent open in the unit.
Old Sep 4, 2007 | 11:02 AM
01 silver sport
I replaced the rear diff sensor but it didn't fix the problem.
I measured the front wheel sppeed sensors with a ohmmeter, both read about 450 ohms. What should they read?
Rear reads about 1500 ohms.
This is a Kelsey-Hayes 4WABS.
I saw a post to remove the right kick panel, jumper a wire to ground and read the ABS flashes. Does anybody have a article for this? I would try it if I had instructions.
Thanks,
Jerry
Old Sep 4, 2007 | 11:14 AM
ranger88a's Avatar
ranger88a
Are all the tires the same?
Old Sep 4, 2007 | 11:34 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
I have the same problem...checked all the sensors and even hooked up to it with a special scanner and all the wheels showed the same speed... so it must be in the ABS controler...i havent looked much into yet though...im hoping that the controller is seperate from the modulator or whatever you want to call it...but the control box does sit on top of the "modulator for the brakes" lol stupid lengo...
Old Sep 4, 2007 | 02:23 PM
01 silver sport
I think the ABS module(brains) is right above the modulator(with all the brake lines)
I wrote the part number down off the module its,
XL3F-9C734-BB
It looks like a motorcraft number. Anybody try to buy one? Or run diagnostics?
Jerry
Old Sep 4, 2007 | 02:25 PM
01 silver sport
All the tires are the same. 2 year old Michelin cross terrain. Great tires in the winter.
All 4 rotors & pads are less than a year old.
I looked at all the ABS parts rockauto com has but didn't see the abs module listed. rock usually has every part commonly avaliable.
Anybody try to buy one? How much?
Thanks,
Jerry
Old Sep 4, 2007 | 05:31 PM
BURNSTOUGHFORD
im going to swap the brains for the modulator off of a wrecked one some time soon....just have to find the time to do it... if its even seperate from the modulator..
Old Sep 4, 2007 | 05:48 PM
01 silver sport
Hi,
I found this site, they rebuild the EHCU electronics for $150. You don't need to remove the whole thing. here's a link
http://www.bba-reman.com/content.asp...ing_bba_repair
The only problem is they say the problem is that the pump runs all the time. My problem is the ABS kicks in at slow speeds all the time.
Anybody try these guys?
There the only ones I've found that rebuild the Kelsey Hayes electronics.
Thanks Jerry
Old Sep 4, 2007 | 07:39 PM
66f25red's Avatar
66f25red
Your ABS motor is running for how long? What speed is this? Does it shut off & when?
Old Sep 4, 2007 | 10:28 PM
BURNSTOUGHFORD
my will kick on from 55-15...and thats it...15-0 its smooth braking...and braking from 55+ is smooth...just from 55-15 it pulses the brakes
Old Sep 4, 2007 | 10:58 PM
66f25red's Avatar
66f25red
So, it is active 55-15, then stops the pulse. Do you have any brake noise? Some systems will activate ABS when a rotor and pad have a harmonic vibration. If you brake firmly to hard 55-15; what happens.
Old Sep 4, 2007 | 11:39 PM
BURNSTOUGHFORD
nope, new pads and rotors.... it did start after some washboards on a gravel road while braking... yup active 55-15 only...right on the money
Old Sep 5, 2007 | 11:35 AM
Deebo's Avatar
Deebo
Are you sure the truck has the right rotors on it?
I had a Econoline van that the rotors were replaced under warranty and the abs would come on after going over a speed bump. I took it back and the rotors on the front didn't have the one rib in them that was solid for the sensor to see it rotating.
Old Sep 5, 2007 | 01:11 PM
66f25red's Avatar
66f25red
also, as I noted earlier, there may be a harmonic being generate upon braking. Sounds like a low note, and it triggers the abs to run. If the wheel sensor cables have tested good by vigoriously twisting them during an ohm test, and the rotors are the correct ones, something as simple as dust on rotors or even a small stone can get kicked up and end up embedded in the pad.
