Sponsored by: Real Truck
Squeaky noise?
Old Jul 23, 2007 | 10:15 PM
John311t's Avatar
John311t
Squeaky noise?
So lately this squeaky noise as been getting worse. When the truck hits a bump it squeaks bad. I went ahead and check everything it all looks good. I had the truck in my driveway and just pushed down on the front end and it did it also. Is it possible my shocks would make a squeaky noise? They are not leaking fluid but what i can see but i can't figure out anything else that would cause it.
Old Dec 23, 2007 | 09:51 AM
Bob's F-250's Avatar
Bob's F-250
squeaky leaf springs
I have an 03 F-250 and noticed a lot of squeaking going on in the front end. I pinpointed the noise to the front edge of the leaf springs. I sprayed garage door lub at the rub point and the squeak disappeared. I am looking for a more permanent solution.
Old Dec 23, 2007 | 10:24 AM
John311t's Avatar
John311t
Oddly enough, this squeaking has stop now that we have been wet out. I used to have to spray wd-40 right between the leaf packs in the front. I went and got some isolators, but it still squeaked. Now that its been wet its been alright.
Old Dec 23, 2007 | 11:20 AM
blue350's Avatar
blue350
Check your sway bar end links as well. They may be worn out or ripped. I have that problem with mine but they ripped due to my own fault.
64rednwhite
Jun 9, 2014 11:04 AM
BarryLM
May 23, 2013 08:57 PM
MBBFord
1997 - 2003 F150
Mar 3, 2007 12:42 PM
MemOrex
Sep 14, 2004 09:16 PM
