do I have a 9" diff
Old Jul 23, 2007 | 04:08 PM
culprit2's Avatar
culprit2
do I have a 9" diff
vin# 2FTDF14G7CCA36522
this is a '82 F-150 ........ I need to know if it has a 9" rear diff....
there is no tag on the diff but on the door says axle 16...... any help would be nice............ thanks...
Old Jul 23, 2007 | 04:46 PM
Matts72's Avatar
Matts72
Does it have a removeable rear cover? if not its a 9". I believe they used the 9" until 83, but you have a Canadian built truck and things can be different with them. Its either a 9" or an 8.8" both are excellent axles.
Old Jul 23, 2007 | 04:57 PM
f100beatertruck's Avatar
f100beatertruck
I've seen 9's in some 84's, plus they're an easy and popular swap.
8.8 has a tin inspection cover on the rear with 10 (?) bolts. The 9" has the differential carrier that bolts in from the front. The rear cover is relatively smooth.
Here's a 9" https://www.ford-trucks.com/article/...ear_Setup.html
Also see here
http://www.coloradok5.com/axleguide.shtml
Not sure what code 16 is. It would be a non-limited slip, but I don't know the ratio. Maybe someone else knows.
Edit - Found a list. Looks like a 3.73 ratio. http://www.drivetrain.com/Fordtrkratio_posidata.html
Old Jul 23, 2007 | 05:06 PM
ri_truck_guy's Avatar
ri_truck_guy
Axle code 16 is a 3.50 ratio axle used in 83, then again in 85-86. Given the years it might indicate an 8.8 inch.
Old Jul 23, 2007 | 08:49 PM
mtflat's Avatar
mtflat
My 86 F150 4x4 came with a 9" ltd slip in 3.50 ratio
Old Jul 23, 2007 | 11:16 PM
culprit2's Avatar
culprit2
thanks for the reply..... no there is no cover.....
