Sponsored by: Real Truck
Shuts off after 2 min.
Old Jul 23, 2007 | 06:29 AM
prommach's Avatar
prommach
Guys, I have a 2001, 250 super duty power stroke with 97K miles. I bought it new never had a problem before.
It will start and runs fine for two minutes. Shuts off just like you turned it off. It will not start again for about 6 to 8 hours. It will run again for about 2 min. again and just shuts off. The fuel is clean and the filter has been replaced. Seems like it is temprature related.
Help!!!!!!!!
Down in Ohio.
Old Jul 23, 2007 | 06:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hi Prommach, welcome to FTE!
Sounds like the CPS needs replacing. A fairly common problem.
Read this:
https://www.ford-trucks.com/article/...ke_Diesel.html
Old Jul 23, 2007 | 07:35 AM
prommach's Avatar
prommach
Is that the Crank or Cam Senser? If so what resets? It seems to be temprature sensitive. After it shuts down it takes 6 -8 hours for it to restart, I tried every hour yesterday. It wouldnt even try to start, after about 8 hours it started right up just like there was nothing wrong and then quit again after 2 minutes.
Old Jul 23, 2007 | 07:54 AM
rmilchman's Avatar
rmilchman
Could it be an oil pressure sensor? I thought the PS would shutdown if it didn't detect enough pressure.
Old Jul 23, 2007 | 08:14 AM
prommach's Avatar
prommach
Oil Pressure as in Lubricating Oil or Fuel?
Old Jul 23, 2007 | 08:42 AM
rmilchman's Avatar
rmilchman
Lubricating
Old Jul 23, 2007 | 09:07 AM
prommach's Avatar
prommach
Thank you!
Old Jul 23, 2007 | 09:32 AM
aldridgec's Avatar
aldridgec
While the PSD needs oil pressure to run the injectors, it doesn't have a switch like some cars that shuts down the fuel pump.
I second the CPS (Cam position sensor) suggestion. Can you scan it to see if it has any codes? PO341 would be the one to see to help confirm CMP. It isn't resetting, it's just flaky.
Old Jul 23, 2007 | 09:38 AM
prommach's Avatar
prommach
Thanks, Going to go and get a CPS now.
Old Jul 23, 2007 | 09:51 AM
rmilchman's Avatar
rmilchman
My mistake. I thought I remember reading somewhere that the PSD will shut itself down in an attempt to prevent itself from self destruction if there is low oil pressure.
Old Jul 24, 2007 | 06:05 AM
prommach's Avatar
prommach
Guy's
Thanks for the help! It was the Cam Shaft Sensor.
carl2591
Jan 25, 2015 10:07 PM
powerstroke97hd
Jan 17, 2011 08:33 PM
F350POS
19
Apr 18, 2010 09:55 AM
bmjd
Sep 2, 2003 03:01 PM
