4Lo broken--HELP!
Old Sep 16, 1999 | 12:25 PM
nissanjon's Avatar
nissanjon
4Lo broken--HELP!
for some reason, my 4Lo doesn't want to stay in gear. i can put it into gear, but the lever just pops out into neutral. i do have a 2" body lift, and i've been told that the lift will cause the body to get in the way of the lever, so i'd have to cut out some metal to give room for the lever. this does not appear to be the case,however. i checked, and there is plenty of room for the lever, but is just doesn't want to stay in gear.
has this ever happened to anyone? and if so, what was the problem, and how can it be fixed.
by the way, i did take the truck off road, and wheeled just fine in 4Hi and 1st gear. is that bad for the truck?
Old Jun 18, 2000 | 11:22 PM
thrasher's Avatar
thrasher
4Lo broken--HELP!
I had a friend that had a 77 short bed 4X4, not long after he bought the truck(new in 76), it started to pop out of gear while off roading. After a while he had to have someone hold it in gear with their foot. just before he sold it he had found out that the linkage was out of adjustment. So you might check the linkage hope this helps.
Old Jun 21, 2000 | 04:24 PM
Bob_VT's Avatar
Bob_VT
4Lo broken--HELP!
What transfer do you have? I recently saw the internal workings of a NP208 transfer that had the same problem. The shift fork is aluminum and has nylon bushings that ride inside it. Well the nylon was work and so was the aluminum. In short it is just "a better idea" cheap design. I have an aluminum transfer in one truck but I also have a NP205 cast iron in the other. Something is to be said about the older cast iron design. Good luck.
Old Jun 2, 2001 | 10:54 PM
shazam's Avatar
shazam
4Lo broken--HELP!
Hey there have you gotten your transfer problem worked out yet .
I put a 3" lift in my 1978 F 350 4X4 and had to take out a good 1 1/2" of tim from the floor pan to get it to stay in ..
DG Homa
Old Jun 3, 2001 | 07:47 AM
tbolt 460's Avatar
tbolt 460
4Lo broken--HELP!
fordman19762003
Dec 2, 2013 05:29 PM
PSDlongbox
Sep 17, 2013 08:20 PM
GNR22
May 31, 2012 11:21 PM
'94Mesquite
Jul 29, 2009 02:56 PM
nissanjon
Offroad & 4x4
16
Apr 17, 2009 03:14 PM
