Aerostar Ford Aerostar
Noisy Howling Pwr Steering Pump?
Old Jul 22, 2007 | 10:06 PM
96_4wdr's Avatar
96_4wdr
usually fine air bubbles in system which are difficult to get out of a Ford system due to design
http://www.cardone.com/english/club/...%2020-0002.pdf
i use my a/c vac. machine with an inline oil catcher
Pwr steering lines breaking down internally and killing your PS system...black gummy thick goo PS fluid is a sign
http://www.cardone.com/english/club/...%2020-0005.pdf
Old Jul 23, 2007 | 10:34 PM
Kruse's Avatar
Kruse
http://www.cardone.com/english/club/Products/STEERING/Protech/Tech_Bulletins/PT%2020-0002.pdf
The last shop that I worked at, a tech who worked there had one of these. I replaced a pump on an Olds, (I think) and within 5 minutes all the foam and howling was gone. I never did buy one myself because I had always replaced them and then let them sit for 8 hours to let it "fix itself", although sometimes that is not always possible.
On the same note, I've used Cardone replacement pumps before and some of them howled, even though by their own posting, they have a cure. I remember a '91 Aerostar of mine that I replaced with a Cardone and I think the howl was worse than the old one I took off. Maybe they have improved over the years.
Old Jul 24, 2007 | 01:26 AM
96_4wdr's Avatar
96_4wdr
if the customer picks it up and runs the pump early, the fine air bubbles will permanently score the pump....will never be quiet again
i like AC Delcos and FoMoCo MC if avail....pricey
Phy
Mar 29, 2011 01:18 PM
jhrobert
Mar 17, 2008 09:41 PM
jake00
Illinois Chapter
Sep 18, 2004 07:04 PM
