Sponsored by: Real Truck
Rear wheelbearrings
Old Jul 22, 2007 | 08:49 PM
Rio_Grande's Avatar
Rio_Grande
Rear wheelbearrings
I apolijise up front, but search seems to be disabled for me and I have a problem. I thought I had a brake squeel so I cleaned the brakes out really good and the squeek persisted causing me to think it may be a wheel bearing or a broken spring in the brake caliber. It is a chiiiiirrrrppppp Chirrrrppppp for about 1/4 wheel turn and only when the wheel turns. I will also check the universals, but it is not that fast.
I have never had the wheelbearings out of the truck. I asume it is similar to any other full float 60 I have worked on but before i take it apart is there anything to be aware of? Any specific procedure required to service these bearings?
Thanks...
Jeff
Old Jul 22, 2007 | 09:42 PM
aldridgec's Avatar
aldridgec
No, they are unit bearings and are not serviceable.
Old Jul 22, 2007 | 10:14 PM
Rio_Grande's Avatar
Rio_Grande
My bad, I read my post again and I didn't specify it is the rear end where the noise is. Sorry bout that.... May not change anything,,, Dang unit bearings are outragously priced, and the non servicable part is unfortunate aswell. The design on the jeep wranglers is similar but smaller. I know from dealing with them that you don't want to buy cheap ones.
Old Jul 22, 2007 | 10:37 PM
aldridgec's Avatar
aldridgec
No, you did. I just had fronts stuck in my mind.
It is rare for the rear bearings to go bad. It is a sterling 10.5 unit. You need a special socket to remove the lock for the bearing, and the seal on the back usually gets destroyed because it is a submerged seal. Gear oil lubes the rear wheel bearings so if they are "squeeking" something is really wrong. My guess is the brakes are causing your issue and you need to check into them further.
Old Jul 22, 2007 | 11:04 PM
Rio_Grande's Avatar
Rio_Grande
Thanks, Brakes are easy,, I just replaced them a while back, but I need to rotate the tires anyway. So I will get back with the solution.
I am a touch disapointed though. I thought I had a 60 full float.... But I have heard good things about the stearling...
Old Jul 22, 2007 | 11:30 PM
Soilman's Avatar
Soilman
The Striling 10.5 is a full float (I think) and it is tougher than a 60 so don't be disappointed. I have never heard of a rear wheel bearing going on any of these trucks and I have more than a few. If the bearing has got a problem than it should be leaking rear end gear oil out the end. If its not leaking oil, I would look for the problem in the brakes.
Old Jul 23, 2007 | 07:08 AM
redford's Avatar
redford
FTE Leadership Emeritus
Do you have a limited slip differential and did you recently change differential fluid?
Old Jul 23, 2007 | 08:13 AM
vettdvr's Avatar
vettdvr
Don't forget the U joints. They will also squeek with rotation of the wheel and noise can come from the rear.
Old Jul 23, 2007 | 09:44 AM
redford's Avatar
redford
You didn't say what wheelbase chassis you have, but if applicable it could also be the carrier bearing.
Old Jul 23, 2007 | 09:55 AM
Rio_Grande's Avatar
Rio_Grande
All good thoughts. It is a crew short bed so it has a carrier bearing. The noise seems a little slow for that, but it could be.
I have the kids today but will crawl under it tonight.
Jeff
Old Jul 23, 2007 | 09:58 AM
redford's Avatar
redford
Oh....also remember the rear also has parking brakes.
Old Jul 23, 2007 | 09:53 PM
Rio_Grande's Avatar
Rio_Grande
I am betting brakes now, I can change the noise and actually eliminate it with application of the brakes.
I was under it tonight and looked at the carrier bearing for the drive shaft. Is there a way to grease that thing? I couldn't find a zerk on it. All u joints are in good shape. I did find what appears to be a rear main seal leak, or maybee a valve cover leak, I can't quite track it down. As much as it cost to put iol in this thing I can't afford to have it leaking out.
Thakns for the replies, It is nice to talk to folks who know the vehicle.
Grease & Gravel
1983 - 2012 Ranger & B-Series
Mar 24, 2017 09:42 PM
Wbrann51
Dec 17, 2016 04:59 PM
redbayredneck
25
Apr 30, 2016 07:57 AM
willowbilly3
1947 and Older Ford Trucks
Feb 11, 2016 08:13 AM
Dale Seeley
Aerostar
48
Jun 11, 2006 09:39 AM
